overload springs?
Old Mar 6, 2007 | 11:00 PM
bigfish5's Avatar
overload springs?
I have a 05 2500, It has somekind of a lift from procomp, it is a suspension lift that was put on before i bought the truck. Here is the problem. This truck squats like a b&%# when i put my boat on it, or a really heavy load in the bed. Can i get the overload springs that come on the 3500, or is there a better "cheaper" idea. Any help with ideas would be appreciated. And also what i should pay for the springs and labor?
Old Mar 7, 2007 | 09:12 AM
Fisherguy's Avatar
I'd go with Firestone air bags, might not be cheaper but they'll be w ay more effective than the overloads and help with the sway a bit as well.
If I ever get a levelling kit I'm going to get them to hold the rear up when we load up for our fishin trips.
Old Mar 7, 2007 | 09:48 AM
jkitterman's Avatar
What size lift kit? Did the lift kit replace the stock springs in the rear or was it a lift block? An airbag kit may not work because of the lifted height without modification.
Old Mar 7, 2007 | 09:55 AM
Fisherguy's Avatar
Good point!
Old Mar 7, 2007 | 04:04 PM
desertram800's Avatar
Do you have the big azz overload leaf that's like 1" thick? I have them and they ride like a rock. I don't think I could make my truck squat if I wanted to!
Old Mar 7, 2007 | 05:54 PM
BR1's Avatar
BR1
speaking of this: do these trucks have like no block in the rear? i have a block that is maybe, 2" thick, but i bet not even, then i have two looks like cut leafs that only extend beyond the u bolts by a couple inches, then the big *** thick one, and then 4 leaves. is that how it is suppose to be? on the 2nd gens, those had 4.5" blocks.
Old Mar 7, 2007 | 06:14 PM
bigfish5's Avatar
reply
this truck has the adjustable springs from procomp. I think the truck sits a little higher in the front than it does in the back. I want to add about 1 inch in height to the rear. So i was thinking i could kill 2birds with 1 stone by adding the overload spring??? it would raise the rear and stop the squat also right? here is a pic of the truck.
Old Mar 7, 2007 | 06:32 PM
bigfish5's Avatar
would this work.
http://www.suspensionconnection.com/...on/61901D.html
Old Mar 7, 2007 | 09:33 PM
Spitse's Avatar
I really like my supersprings. Helped the squat on my 2500 with the TT. They only start helping when the weight in the truck gets to a certin point making a smoother ride than with standard overloads. Took about 30 min to install both sides.
Old Mar 7, 2007 | 09:58 PM
bigfish5's Avatar
i like the idea of supersprings also,
i like the idea of supersprings also, but i think i was told they will not work because of the lift kit. I would love to be wrong about this.
Old Mar 7, 2007 | 10:19 PM
gRahAM Diesel's Avatar
Bigfish5 whatever you do you better do it quickly as the truck squat problem appears to have had a profound impact on the family. I noticed the little one "squatting" in the background of the pic; sorry, I couldnt resist
Old Mar 8, 2007 | 05:27 PM
bigfish5's Avatar
i will move quickly to resolve the problem, he has been in that position for the last 4 months.
Wesjr55
Nov 3, 2006 02:13 PM
qwest
May 18, 2006 09:46 AM
DuaneWKKC
Jan 28, 2005 06:11 PM
M0J0
17
Jan 22, 2005 07:42 PM
ckennedy
Nov 29, 2004 08:37 PM
