outside temp display
I did what testing I could do without any books or anything. Just guessing I did remove it and OHM it out, it was about 15kom @ garage temp which was about 38-40 deg F Then as I warmed it up in me hands the resistance dropped to about 11kohms @ a temp I dodn't know.
Thats why I said I need a service manual. Is that where you got that test or do you work on them for a living and have access to other data?
I'm pretty sure there is a TSB or something that explains this. The ambient temp reading holds initially when started so that the CEL light doesn't come on because of the difference in ambient and battery/intake temp sensor. It takes about a minute for it to start adjusting to actual temp.
It helps reduce the following codes:
P0071 - Inlet Air Temperature Sensor Rationality
P0111 - Intake Air Temperature (IAT) Sensor Rationality
P0514 - Battery Temperature Sensor Rationality
Every morning when I leave my garage, it stays at the same temp for about a mile then starts rising/dropping to actual ambient temperature.
Hub
but mines has no issues.
its sticks..
Mine stuck this summer after taking it thru a carwash. Stuck for 2 days. kept reading 88F when it was over 100F. It works ok now and is always within 2 degrees of the reported temps on the local radio.
Erik
Erik
ppsi
Oct 13, 2011 07:35 PM
MossyOakCTD
19
Dec 28, 2010 09:11 PM
thewirsboguy
Jul 5, 2008 08:34 AM
turbox2
Feb 6, 2006 07:44 PM
