OK, where the heck does it go????
I drive with my AC on all the time now that summer has finally arrived here in sunny, SOCAL. So, just about every (make that every) car I have ever owned dripped AC condensation (water) on the ground after driving any distance with the AC on. This truck does not seem to sweat the stuff. It has to be condensing water out of the air. Where is it going????
Neil
Neil
Wow, I just returned from a one month trip to sunny Florida, and in the high heat and humidity it looked like it was raining under my truck!! Maybe yours has one of those new fangled whatchamacallitevaporators?!
This normal for ANY air conditioning system. Take a look at an air conditioner for a house and you will see a drain to take away the water. It is a natural law that when air is cooled that any water vapor present will condense out of it. The higher the humidity, ie Florida coast, the more water that will condense from the air as it is cooled. The opposite of course also applies, when air is heated, the more water it can absorb. Your truck A/C is taking the water present in the air and dumping it on the ground.
If you're running the a/c on max like I do, it won't drain as much. Mine doesn't drain much at all after it's cooled off inside. It's been hotter'n the hinges of heck here in Florida. It was 101*F on the blacktop coming through Gainesville last week and high humidity. The sweat rolls off just standing in the shade. If I run the a/c on other than max, it seems like it never cools off inside and the fumes from other vehicles stinks with the outside air coming in. If it ain't that, you might oughta' check the carpet.
Your drain isn't dripping right on the downpipe and evaporating is it?
Re: OK, where the heck does it go????
Neil
Neil
I've been under my truck 3 times looking for the drain to unplug it but I'll be damned if I can find it!!!
It's so close to the passenger-side frame rail, you may be missing it. I suspect algea accumulated in the hose stopping it up. Either it's stopped up, or the end of the drain hose has enough algea inside that is trickles out and onto the frame rail and may be flowing down the frame rail until it reaches a point where it begins uphill then runs off. Nat
Originally posted by VPI
Here in humid Tennessee mine rains under my truck when I run the AC
I looked again when I got home from work last night. No time crawl under though. No drips noticed. Hose must be plugged or condensation is hitting something that's holding it or evaporating it. I haven't seen this since it was new (still only has 3k mi on it) so I doubt if it's algae.
I only run at max AC. But I don't see why that would matter. Condensation is caused by the cooling of humid air (as air cools, it loses its capacity to hold moisture). The colder the components, the more I would expect condensation to accumulate and, eventually, run off somewhere. It's the somewhere that I have yet to find. Hmmm, maybe by running at max, I'm drying out the air more by recycling the colder air. I suppose that's possible. Is the condensation forming from outside air contacting the components or the air that's actually being cooled and pumped thru the cabin?
Ahhh, something to do this weekend . . .
