ok have steering popping going on.
looked at a couple of threads but got tired of reading of all the flaming going on...i have read that there is a steering gear brace....is this true? where can i get one...??? i have a 06 mega cab. 5.9 turbo
thanks for the links...i will check them out
it only pops once in awhile not all the time....and only when turning. just one pop then nothing...turn the other direction and maybe a pop again...i noticed the other day when i went through a auto car wash that the pop wasnt as loud or harsh...shrug....i guess i need to get a neighbor to hang on under my truck while i drive around the block....... j/k. i have the steering upgade linkage..th AE model.. but the popping was before that anyways. just the popping started after the 2" lift and all those bolts are tight...
kind of sounds like the classic loose track bar bolt syndrome...really crank on the frame side. or maybe dry ball joints. How does the steering feel? unless you have play in the sector shaft on gear box the brace, even though it is a good idea, probably won't solve the popping.
as soon as i figure out my strapping system for riding under the truck and performing "what the **** is that noise" diagnostics i will let your neighbor know
Mine was popping pretty bad too in slow moving, turning, situations. The "ultimate track bar hardware" by Lazarsmith fixed it. http://www.lazarsmith.com/SSSSS.html
The stock trac bar bolts were moving in the mount. Not any more.
http://www.genosgarage.com/prodinfo....er=BORG-000951
Also, some guys have had good luck replacing their steering shaft with a Borgeson unit.
I replaced my stock track bar bolts with grade 9 fine threaded bolts, 9/16 by 2 1/2" with a locking nut. The bolt is a little bigger than the metric bolt that it comes with, but not by much. It still fit through the lazersmiths offset bushing, but it was tight.
My steering linkage is totally wore out, the 2 outside ones that are greasable are still fine. Guess I'll see how good my extended warranty is.
swampdiesel,
I have the defiant and it took about 30 minutes to install. The ssss looks more stout, but still shouldn't take that long. Remember to support the sway bar with a jackstand when you loosen it or it will swing down and possibly hit your head.
If you consider the defiant, Paul is awesome to deal with and it's only around $165.
Pete
(xploretx)
Pete
Pete
(xploretx)
Pete
guido
Jul 29, 2009 04:27 PM
mstep3
May 16, 2009 07:30 PM
david_4x4
Apr 18, 2007 09:27 PM
MikeyB
Apr 8, 2004 05:21 PM
