oil on truck
Old Jul 1, 2008 | 12:49 PM
ian515's Avatar
oil on truck
I drove down a road that was being freshly tarred. now I have specks of oil on my rig. whats the best way to get that off, seeing as water wont do the trick?
Old Jul 1, 2008 | 01:01 PM
louielouie's Avatar
3M makes a 'bug & bar' remover in a non-aerosol can that I've seen at NAPA plus Griot's Garage - then there's an aerosol version in a tall blue can (can't remember the name but probably the same folks who make that smelly engine cleaner) that sez "Bug and Tar" on the front. Give them some time to dissolve the tar or bug jerky and don't rub hard since you may grind the hard bits into the paint.
Old Jul 1, 2008 | 01:10 PM
ian515's Avatar
thanks! I will pick that up.
Old Jul 1, 2008 | 01:53 PM
Grit Dog's Avatar
lacquer thinner will take the road tar/oil off easily, but it strips the wax off too, so you'll need to re-wax that area.
Old Jul 1, 2008 | 02:02 PM
donhov's Avatar
I have also heard that WD-40 works well for removing these types of problems. As above probably also removes the wax so ...Give it a shot.
Old Jul 1, 2008 | 03:06 PM
Desert Dually's Avatar
check this out
believe it or not, baby oil soaked into a small washcloth will take it right off
Old Jul 1, 2008 | 04:48 PM
0524VHO's Avatar
wd40 works real good on tar
Old Jul 2, 2008 | 01:14 PM
DBLR's Avatar
I would not use baby oil on any truck or car I plan on owning for any length of time.
Old Jul 2, 2008 | 03:58 PM
jamesbfishin's Avatar
I've never used that method, actually never heard of it. But what is the reason behind your statement, does it destroy paint?
Old Jul 2, 2008 | 06:06 PM
ian515's Avatar
this is what I picked up....think it should work?
http://www.detailing4less.com/rain-x...tle-95819.html
Old Jul 2, 2008 | 07:50 PM
Hounddog's Avatar
WD40 or a little motor oil on a rag works just fine.
Old Jul 2, 2008 | 10:43 PM
SD90's Avatar
Bounce dryer sheets soaked in warm water. Also works great for bugs!
Old Jul 3, 2008 | 03:09 PM
DBLR's Avatar
I have a friend who paints cars and he told me to never let baby oil get on the paint as it will cause a lot of problems if you ever need the car painted for any reason. Some car lot detailer's use baby oil on the rubber around windows to make it look nice for when you go to buy the car.
Old Jul 3, 2008 | 05:43 PM
mini14's Avatar
baby oil is mineral oil with fragrence, cant c any harm in that.....ill give it a shot.
ian515
Oct 16, 2007 07:02 PM
TxDiesel007
15
Jan 18, 2006 01:19 PM
