Motor driven on board air
Old Dec 16, 2007 | 08:21 PM
06 DIESEL's Avatar
I am looking at getting on board air but want to be able to run air tools off of it so i am looking for a motor driven compressor. Anyone know of a kit for third gens? If I have to I will piece it together but I would rather just purchase a kit with all of the pieces to make it easier. Would a semi compressor work on our trucks if I fabed up a bracket to mount it where the second CP3 is always placed? I have been looking for a little while but I keep finding the cheap electric one's that can not air up a tire without having to wait to let the pump catch up.
Thanks in advance
06 DIESEL
Old Dec 16, 2007 | 08:32 PM
cbrahs's Avatar
compressors on a Semi are gear driven, you would have to fab some sort of pully system. I know that on the jeep side (rock crawling forums) people have used a/c compressors to do this. I know of a guy here in town that has one on his jeep and it does the job on the trail. i have heard there are companies that use a/c compressor style pumps. check this link out
http://jeep.off-road.com/jeep/articl....jsp?id=261434
Old Dec 16, 2007 | 08:38 PM
Halibrand's Avatar
Semi-Trucks typically use a gear driven compressor (actually mated up behind the fuel pump). BUT they often use belt driven York compresors for their AC systems. These are the units you want because they are internally lubricated with oil, not like other ones that use the freon as a lubricant.
You could make a setup yourself, or simply buy a kit from Kilby Enterprises that has everything you need.
http://www.polyperformance.com/shop/...cat=524&page=1
http://www.kilbyenterprises.com/
The kit is cheaper from Kilby direct, but I belive you have to call them directl to purchase it.
Old Dec 16, 2007 | 08:43 PM
pind's Avatar
and for those who want the ultimate ni on-board, engine driven air supplies
http://vmacair.com/
There you have it, big bucks, but man do they work
Old Dec 16, 2007 | 08:48 PM
Halibrand's Avatar
Holy crap, those are insane! Says they will run TWO jackhammers and have been used for shop air in a pinch.
Wow.
Old Dec 16, 2007 | 08:58 PM
pind's Avatar
most service trucks come equipped with those compressors now, and yes, they do work as advertised.
Very few breakdowns as well, treat them right, service them at the proper times, and feed them clean air, they'll outlast the truck they are mounted in.
I have seen a couple of them used as shop air, when the big screw went down, and they don't provide the HUGE cfm, but they'll do.
Old Dec 16, 2007 | 09:01 PM
cbrahs's Avatar
that is ridicules! now that would supply air for my train horns!! LOL
Old Dec 16, 2007 | 09:13 PM
06 DIESEL's Avatar
Looks like I need to save some money before I can afford any of these kits, but I was expecting that. Thanks for the replies and when I get a kit I will be sure to post up pictures of the install and how I like it. I really like that they make the kit without me having to piece together a kit, an be able to run air tools off of them without a problem is great.
Old Dec 16, 2007 | 09:19 PM
solar1's Avatar
I haven't thought about putting one on my CTD but I do have a motor driven York setup on my Jeep and can fill up a 33" tire from 8 psi to 30 psi in about 30-35 seconds. I have a 2.5 gallon tank and run impact wrenchs off of it all of the time.
Good resources:
Donor vehicles for a York F-210:
http://www.4staroffroad.com/tech/OBADonors.htm
Stu's write up:
http://www.stu-offroad.com/otherwriteups/oba/oba-1.htm
Old Dec 17, 2007 | 06:06 AM
TAS's Avatar
TAS
This is what Mrs Santa is bring'n me. (CO2)
http://www.4x4rockshop.com/scripts/p...idproduct=2166
I like the portability of it. I can move it from my truck to my jeep when we head out on a ride.
Old Dec 17, 2007 | 08:38 AM
moneytlks01's Avatar
unless you are stuck on an engine mounted compressor i would get this...
http://www.oasisoffroad.com/p2.html
i have installed one with a set of k5la horns and a 16 gallon tank, the compressor doesnt even sweat them. you can run a 1/2" impact off the compressor alone (no tank)! they are awesome compressors and have great customer support.
Old Dec 17, 2007 | 01:18 PM
HOV's Avatar
HOV
^^ That looks completely awesome. How much is it?
Old Dec 17, 2007 | 04:25 PM
jballou's Avatar
one thousand dollars... just checked one source online.
Old Dec 18, 2007 | 06:47 AM
yep they are around 1k but worth every penny!
ratat98
Dec 21, 2009 08:36 PM
HMX-1
Oct 12, 2009 01:44 AM
jensenkennels
Jun 4, 2009 11:57 AM
Timmer
Dec 14, 2007 10:56 PM
classic01
May 11, 2005 05:26 PM
