Leak In Cab Lights
Leak In Cab Lights
Has anyone found a fix for leaky cab lights? I have had my pickup for about a year and they just started leaking. Also, the water was coming out through the computer and I am nervous about shorts. . . Has anyone had this problem?
I am under warrently; however, I have read on these threads that this was a common problem so if they fix it and it happens again (I am out of warrently in 6,000 miles) I am on the hook.
There is a revised seal for the roof lights, and there is a TSB directing technicians to replace the lights with the new ones to solve the problem. As long as the truck is still under warranty, it should be covered.
Here's a link to the TSB.
http://dodgeram.info/tsb/2006/23-009-06.htm
Its a warranty thing, one of mine had a been tightened too much at the factory and cracked the lens, dealer has heavy duty replacements with new seals as well all under waranty no worries
just made an appointment myself this afternoon over the phone. I mentioned that they were leaking and that there was a TSB out on them. she replied that it was strange that they were leaking?!?! oh well let them sort it out I have tsb printouts in hand.
RTV silicone will solve all your problems. Takes about 10 min, costs a few bucks and no dealer hassles. Unless the lens is cracked then replace it. Personally I'd rather slam my hand in the door than deal with the dealer.
DEFINITELY let the Dealer screw with it; no pun intended...
We had same thing on the 2004 one ton, water came down the column at the driver.
Same thing; little dab of silicone works very nicely cause I didn't want the hassle from the dealer.............
Good Luck, Enjoy the truck!
joem
Dec 23, 2012 01:23 PM
proudpapa97
May 4, 2008 06:50 PM
rollerink
Apr 9, 2008 08:47 PM
jmeade
14
Jul 27, 2007 01:44 PM
CHarlan
Aug 6, 2003 08:40 PM
