Keyless alarm lights and horn?
My 06 has keyless alarm and when I got it the light and horn would sound when you would lock the truck. And the light would flash when you would unlock the truck. NOW I get only the horn and no lights??? How did this happen is something broke or did I change something I didn't know about? I would actually prefer it if I could get the lights to flash and NOT the horn. Any help would be great!
you can program it yourself....it is all tied with your auto door locks...there is a yellow page in back of owners manual that has the correct sequence.
when i lock my truck..one push sets it and it flashes lights one time about 20-30 seconds later. if i give two pushes it activates immediately.
mine is very sensitive even after bumping both shock and arming sensitivity way down.....
i am not sure how you ended up with the horn and no lights but the prosedure to cancel the horn on lock is "press and hold the lock button, continue to hold it for at least 4 seconds but not longer than 10, then press and hold the panic button while still holding lock then release both at the same time. this procedure should work if not it is in the owners manual.
joelayan
02-19-2009 08:02 AM
2500CTD
01-30-2007 05:08 AM
rattle_rattle
11-21-2003 05:02 PM
