The Infamous HVAC Door Issue Strikes
Quick update: changed out a faulty u-joint... and repaired the wiring for the rear door windows and locks. Did a fuel injector (#6 - what a pain). Waiting for my tail light to arrive for a quick install. And I need to do the Donaldson muffler; then the fan bearings...
Can some one send me a diagram of the procedure to take a dash off my 06 Cummings to fix either the blend door or the recir door
tstewart1@frontier.com
Thanks
Thanks
Thanks
Thanks
I wish I could give ratlratl a big hug. I removed the dash and air handler box today to replace the heater and AC core. His directions in this thread were perfect. The job was much easier than I thought with his directions. In less than 3 hours I had the air box out and taken apart. I took my time and grouped each set of bolts with a note where they came from.
If I have to do it again I think I could have the air box out in 1.5 hours. The neatest thing was just removing the right side of the dash and placing it on the seat. I did not remove the dash completely out of the truck.
Again, thank you ratlratl.
Bobby
Bobby
I know this is an old thread. but I have the same issue. i have replaced all the doors with heatertreater doors except the ones you cut out at heatertreaters suggestion. also i have the no cold air on the passenger side. so i guess that part is freon. if I pull the whole thing out and fix this then refill with freeze 12 or one of the hc112a variants, will i notice much of a difference?
I just finished pulling the dash and replacing the broken doors in my HVAC box. After putting everything back together, the AC blower motor will not come on! The blower motor worked great before pulling the dash! What could cause the AC blower motor to not work? The new blend doors are working fine. Did I miss plugging in a wire to the blower or something?
Is there a wire connection that gives power to the blower motor resistor and blower motor?
Just wondering how many key starts does it take for the computer to do a recalibration test of the actuators?
I had the recirc door fail over a year ago. My blend door failed a month or so ago so I have assumed the computer detected an error and did a shut down. I replaced all 3 today. Recirc, Blend and Mode 1. Mode 1 was fine but I replaced it just because. Its working fine and the recirc is kinda working. Its not moving proper in all settings but working. The blend door simply moves to heat and that's it. testing the actuator is is strong and moves both directions. I am thinking it needs to do a recalibration. I have pulled batteries with no luck and my scan tool cannot see HVAC codes or issue a calibration reset instruction. I was just wondering how many key cycles it takes for the truck to do it on its own.
47
47
