HVAC door/ defroster question.....sorry
Old Sep 5, 2013 | 08:26 PM
bigb2709's Avatar
Just the other day when I turned on the defroster on hot I noticed that the air coming out of the defroster was cool. Truck was at temperature. So I switched back to the dash vents and the air came out of them hot. I switched back to cold and the dash air blowed cold. Switched it back to hot and it blew hot. So then I switched to the defroster and the air was cool. I can't get hot air to blow out of the defroster but I can out of the dash vents. Cold A/C works good out of all the vents when selected. Door I have a broken door or another problem? Thanks.
Old Sep 28, 2013 | 05:33 PM
bigb2709's Avatar
No one has had this problem before? Wow. Thanks anyway........
Old Oct 5, 2013 | 10:22 PM
Jeff in TD's Avatar
I wouldn't think that would be a blend door issue, or temp control wouldn't work in any mode.
These trucks activate the AC compressor in defrost mode (as a dehumidifier) so the air on defrost also tends to not be as warm.
I wonder if that could be what you are seeing.
Old Dec 12, 2013 | 09:45 PM
VBixler's Avatar
I have the same problem with my 06 mega cab, I have replaced mode 1 & 2 doors, blend door and recirc door with heatertreater doors and new actuators, new t-stat one from cummins, not fixed yet, mine seems to blow warm air on recirc and cool air thru def vents when on defrost, my A/C doesn't work. I also noticed even on defrost with cool air coming form def vents I still have hot air coming from my rear seat vent. Am going to tear into my heater box again try new heater core since I need to replace the evaporator core anyway. The heater cores are very small.
Old Dec 13, 2013 | 07:42 AM
Jbremount's Avatar
This!
http://www.heatertreater.net/magento...ram-02-08.html
barttly
Jul 18, 2013 08:39 PM
BlueOx1
Mar 18, 2010 07:48 AM
Totallyrad
Jan 7, 2008 05:31 PM
Tommy93w350
Sep 28, 2006 02:53 PM
