help settle a bet
Old Jan 9, 2009 | 09:36 AM
ratsun's Avatar
Originally Posted by Mocho
Haven't weight it empty but with a sled deck and two sleds, half tank of diesel and me in it 10,000lbs. Empty with me in it full of diesel i'm assuming around 8,200lbs or so.
Since it's sort of on topic, does anyone know what you can legally carry on these trucks? I'm trying to find out what i'm legally allowed to haul with my 04 3500 and found about 10 different answers. Don't want to get caught overweight.
There is a door sticker that tells you your GVW
My dually is #12k and my 2500s are #8800 and my buddies SRW 3500 is #9200
Old Jan 9, 2009 | 09:45 AM
1-2-3's Avatar
Just a plain ole guy
Depends. If he's taking Two Ton Tina on a date, or her sister Henryetta Heavylunch, it will be well over 9000 pounds. Even more if it's a double date.
Old Jan 9, 2009 | 10:02 AM
white Lightning's Avatar
GVW on my 2007 3500 SRW short bed quad cab is 10,001LBS
Old Jan 9, 2009 | 10:23 AM
SundayMoney's Avatar
I think you meant 10,100.
Old Jan 9, 2009 | 10:27 AM
I didn't see anyone answer your question about GVWR. Basically,the GVWR is the max that Dodge says your truck can weigh.
My 3500 SRW has a GVWR of 10,100lbs. My truck actually weighs 7200 empty. That means I can add 2900lbs of cargo before I'm overloading the truck per Dodge.
Old Jan 9, 2009 | 01:24 PM
Mocho's Avatar
Ok here's my question, if the axles are 6k and 5k can't per DOT is concerned haul 11k? I really don't care what Dodge says, i'm just worried about DOT pulling me to the scales. Because I was 10k already, and I plan to have 3 more people in the cab, a bunch of gear, and the pin weight of a 2k trailer, which will be another 1,000lbs. I know the truck will handle it like nothing, but don't need to have problems with DOT.
10,000 is nothing, I know all of the stuff in my box is 1,800lbs very max. Sure isn't a lot of weight for a 1 ton
Old Jan 9, 2009 | 07:23 PM
DENVERDODGE04's Avatar
Originally Posted by mrblond
I found this on dodge.com
hemi
With 4.10 Axle Ratio You Can Tow 10850 lbs
Gross Vehicle Weight Rating(GVWR)=8800
Payload=2813
Curb Weight=5987
Curb WeightFront/Rear=3420/2567
GAWRFront/Rear=5200/6010
Gross Combination Weight Rating(GCWR)=17000
CTD
With 3.73 Axle Ratio You Can Tow 12850 lbs
Gross Vehicle Weight Rating(GVWR)=9000
Payload=2015
Curb Weight=6985
Curb WeightFront/Rear=4343/2642
Gross Combination Weight Rating(GCWR)=20000
see i don't understand that does the hemi use the same axles under the hemi 2500? or are all the 2500's the same suspension wether its a hemi or not? if they are the same then why the 200 pound differance?
Old Jan 10, 2009 | 12:00 AM
mrblond's Avatar
Do you mean 2Klbs difference in towing capacity?
Curb weight=no payload
GVRW= with payload
btw, you won the bet!
Old Jan 10, 2009 | 09:15 AM
Asher's Avatar
I think he is talking about the GVWR.. The only thing I could guess is hemi trucks use a little smaller rear end then the CTD's do... I don't know if the axle strenght is the same or not, but the ring and pinion are smaller...
Old Jan 10, 2009 | 06:53 PM
BroncoHound's Avatar
hemi 2500's have 10.5" rear axles. CTD 2500's have 11.5" rear axles.
Old Jan 10, 2009 | 06:55 PM
Correct. DOT is primarily concerned with axle ratings and tire ratings.
Diesel Demon
Feb 9, 2009 04:19 PM
DuaneWKKC
Jun 9, 2006 08:37 AM
sosborn
Feb 18, 2006 11:20 PM
INsIdious
Apr 3, 2004 01:55 AM
fireout2002
16
Feb 10, 2004 08:53 PM
