hellwig swaybar fittment w/oversized spare.
Old Jun 16, 2011 | 09:22 AM
Danderson's Avatar
Are any of you 3rd gen guys running Hellwig part# 7658(our application#) also packing an oversized spare back there? The instructions show a stock spare and good clearance. I've got a 285-75-17(34") spare and am curious if the vertical rods will clear. Thanks in advance.
Old Jun 16, 2011 | 10:20 AM
bigwheels94's Avatar
I have the same tire, & a Helwig bar on my truck. It's close, but it will fit.
Old Jun 16, 2011 | 10:35 AM
Danderson's Avatar
Thanks. I'm running a 285-75-17 which is 1.3" taller than your signature tire. Tighter yet?
Old Jun 17, 2011 | 10:22 PM
TexasCTD's Avatar
im running a 285/70 tire for a spare with the hellwig. It's tight but it fits. Im not sure about a 285/75....that's going to prob be to tight.
Old Jun 21, 2011 | 10:25 PM
blackstx's Avatar
I have a 35X12.50 on the stock "spare" rim under the truck with the Hellwig sway bar. it does rest against the sway bar end links, but it does fit.
Old Jun 22, 2011 | 09:15 AM
Danderson's Avatar
I'm going to have to figure something else out. I wish Hellwig would have bowed out the links more or something to enable a larger spare to be placed/removed easily. Thanks for the responses.
Old Jul 6, 2011 | 08:32 PM
Danderson's Avatar
Hellwig swaybar,yeah!
Got the Hellwig 1 1/8" swaybar installed and what an improvement in handling! Much better handling with decreased lean and control. With Thuren's coils and his custom valved Kings this handles super! I hardly know the camper is on there(except at the pump)
My spare fit easily and a 35" will fit also pulled to the hitch. Bar came powdercoated with a hammertone finish.
Thanks for the replies!
Old Jul 12, 2011 | 08:04 AM
mdbrown's Avatar
From: Laughlin, NV and on Lake Fork east of Dallas.
I installed the same Hellwig sway bar on my 2004.5 one ton, 2wd. I had to use care putting the spare in place, but it fits - barely. I too have 285/75/17 tires - Nitto Dura Grappler.
Old Jul 12, 2011 | 12:05 PM
Danderson's Avatar
Yeah with the 285-75-17's,I noticed that under full compression the tire could hit the Mag-Hytec cover. Solution was to pull the tire rearward toward the hitch while my wife re-tightened it. I then use a 3" ratchet strap with the hooks inserted into the two holes on the inside of the frame rails to secure the spare further. My winch died on the last truck and I don't trust them.
My buddy's ordered the Big Wig 1 5/8" bar for his '05 w/9.5' hardsided camper.
Danderson
Apr 23, 2011 09:14 PM
johnnyboy_10138
Sep 7, 2009 10:05 PM
jimmyd
Apr 19, 2009 01:17 PM
Boatnik
Nov 6, 2007 07:52 PM
davelinde
Jul 13, 2004 02:15 PM
