headlight switch wiring diagram for aux lights
Old Jan 21, 2010 | 02:36 PM
SD-Dave's Avatar
I have a 2008 Ram Quad Cab Diesel ST.
it didn't have factor fogs etc. I have installed a set of KC fog light and a set of KC driving lights. They get power in the ignition on position only. Issue is that you have to accuate them from a seperate dash switch on/off.
What I would like to have them operate that when the power switches are on....the fogs are on with low beam and driving lights come on with high beams only (driving lights are off when you are on low beam).
Not sure how to accomplish this....might figure it out if I had a wiring diagram of the headlight switch.
Anyone done this? Know how to accomplish this
Thanks
Dave
ps. here is a photo of it.
2008 Ram ST 2500 4WD Diesel 6-speed manual. Kore Suspension, Bilstein Shocks, XD 17X9 Wheels, Pro-comp Ext-AT's 305/70-17 Ranchhand Bumpers, toolbox backrack, ect.
Attached Thumbnails headlight switch wiring diagram for aux lights-img00007-20091108-1108.jpg
Old Jan 21, 2010 | 03:21 PM
cbrahs's Avatar
actually your stock fogs should be on only when in low beam and off when in high.
i can get you a wiring pin out of the switch when I get home. for some reason, dealerconnect pics are not coming up on this computer.
Old Jan 21, 2010 | 03:23 PM
cbrahs's Avatar
here is the pin out of the switch. the number 1. 2. 3. etc is the cavity position of the plug.
1 L116 20WT/LG HEADLAMP/FOG LAMP SWITCH SIGNAL
2 E2 20OR/BR PANEL LAMPS DIMMER SIGNAL
3 L115 20WT/YL HEADLAMP SWITCH RETURN
4 E19 20OR/BR HEADLAMP SWITCH DIMMER SIGNAL
5 Z407 20BK/OR GROUND
6 L914 20WT/LG CARGO LAMP SWITCH SIGNAL
The L116, E2, L115, E19, Z407, L914 are the circuits
20WT/LG = 20 gauge wire, white with light green stripe etc....
Old Jan 21, 2010 | 08:56 PM
06dodge4x4's Avatar
I have driving lights that come on with my high beams. I tapped power from the hot wire on the high beam to power a relay that runs the power to the driving lights. Of course everything is fused!
Old Jan 22, 2010 | 07:58 AM
SD-Dave's Avatar
thanks cbrahs....that should help
all my previous trucks had fogs on low and driving lites on high beam....when you activated the toggle switches they were hot and one set or the other was on depending if you were in high beam or low beam....worked well. In our state only one set of aux lites can be on at any time so this is a workable set up.
Old Jan 22, 2010 | 12:31 PM
cbrahs's Avatar
the harnesses are the same (under the dash), the headlight switch is the only difference. with factory fogs, or without. so you should be able to tap into the harness with the wt/lg wire to toggle and activate your fogs
Old Jan 22, 2010 | 02:37 PM
SD-Dave's Avatar
Cbrah's
maybe I am dumb (good chance if you ask many) but can you tell me what pins would be the low beam and high beam....those are the ones I believe I would need to create the control activation for my lamps....based upon what I am reading I am not seeing clearly which ones of that switch pin setup I would use for my intented purpose.
any help greatly appreciated
hope you understand my plan.
Dave
Old Jan 22, 2010 | 02:53 PM
cbrahs's Avatar
let me look. that is going to be a different connector. you want the wires at the multi function switch or at the headlight?
Old Jan 22, 2010 | 02:57 PM
cbrahs's Avatar
headlamp on the drivers side
1 L43 20WT/DB LEFT LOW BEAM DRIVER
2 Z345 20BK/LB GROUND
3 L33 20WT/LG LEFT HIGH BEAM DRIVER
Multifunction switch
1 G194 20VT/LG WASH/BEAM SELECT SWITCH SIGNAL
2 L900 20WT/YL WIPER/TURN/BEAM SELECT SWITCH RETURN
3 L12 20WT/OR TURN LAMPS SWITCH SIGNAL
4 W52 20BR/YL INTERMITTENT WIPER SWITCH SIGNAL
looks like your best bet would be to tap off of headlight wiring with a relay to actuate your other lights.
4RnrRick
Apr 17, 2019 11:01 AM
bhoeffner
Jan 18, 2013 09:00 PM
bigbaddiesel416
Mar 1, 2009 09:24 PM
MR HYDROSEED
Feb 16, 2007 07:03 PM
Blast54
Nov 2, 2003 01:46 AM
