Fuel gauge stuck
Old Feb 11, 2013 | 09:49 PM
Nscovanner's Avatar
Fuel gauge stuck
I have searched the forums for information about this topic and did not find much. I have an 04 2500 with a 5.9l in it. It is my second engine. The most resent problems is my fuel gauge first started going from what I believed the actual level to be, to full while I was driving. But the truck sat all weekend and now it is stuck on empty and the low fuel light is on. It has not moved and again seems stuck, I drove over 50 miles today and no change with gauge. Any help would be great.
Thank you,
Old Feb 11, 2013 | 11:58 PM
papaduck's Avatar
You can test the gauge cluster by holding the trip reset button down while you turn the key on, do not start, once the test starts release the button. This will tell you in the gauge is bad or if it is the probably the sending unit.
Old Feb 13, 2013 | 07:16 AM
1-2-3's Avatar
Just a plain ole guy
Snap a pic of the speedo when it pegs and tell everyone your truck goes that fast.
Old Feb 14, 2013 | 07:23 PM
Nscovanner's Avatar
I did the test and everything checked out ok, does that mean it is the sending unit? If so is that located in the tank? And that's a great idea to get a picture of the speedometer when it's pegged out!
Old Feb 14, 2013 | 09:21 PM
papaduck's Avatar
It is very likely that it is the sending unit in the tank.
Old Feb 18, 2013 | 04:05 AM
trik396's Avatar
Mine is doing same thing! Going to have to live with it for awhile.
Old Feb 18, 2013 | 08:21 AM
Spooler's Avatar
Yeap, sending unit. They are not hard to do, just make sure the tank is about empty or just pull the bed.
Old Feb 21, 2013 | 11:17 AM
Nscovanner's Avatar
So does this mean my fuel pump is going to go out or just a bad sending unit to the gauge.
Old Feb 21, 2013 | 12:22 PM
papaduck's Avatar
The fuel pump and gauge sending unit are in the same module if yours has been replaced with the in tank pump. The original pump was on the filter in the '03 and '04 models.
If your pump is not in the tank then the sending unit is not expensive but if it is in the tank then the unit is not cheep. Now would be a good time to go for a Fass or Airdog with additional filteration and go with just a sending unit in the tank.
Old Feb 21, 2013 | 01:08 PM
Nscovanner's Avatar
I believe right after I got the truck the lift pump with out and the dealer moved the pump to the tank, is there a way to check. Also other then the gauge not working should I be worried about the lift pump just stopping or do I have time put some extra money to buy an aftermarket pump system.
Old Feb 21, 2013 | 01:19 PM
Hintonc393's Avatar
I would not worry about the pump just stopping, more than likely you just have sending unit problems.
Old Feb 21, 2013 | 01:22 PM
Hintonc393's Avatar
It is possible to have issues with the wiring going to the sending unit causing this problem. Wouldn't hurt to crawl under the truck and just check over the wiring going to the tank and see if it has been hit or smashed. Wiggle the harness and see if it starts to work again.
birdboy
Dec 12, 2018 09:02 PM
birdboy
Apr 21, 2012 09:44 PM
Baja
Jan 29, 2008 08:17 PM
hemertwv
Dec 15, 2005 10:25 PM
04ctd
Sep 14, 2004 04:43 PM
