electrical question(CTD rookie)
Old Nov 5, 2009 | 11:36 AM
steve936's Avatar
Lads....
While sitting, idling at a traffic light or in my driveway while warming up, with lights on, there seems to be a brief drop in voltage, slightly dimming my lights. The drop is very brief, and it cycles pretty regularly.
Is this indicative of a potential problem or with the weather turning colder here in the NE, is this normal? I seem to remember some discussion about a "grid heater". Can someone explain this to me and do you think this could be my situation?
Thank you in advance for your insight.
***EDIT***
The search feature is your friend. I just found a thread started in 2004 that addresses this very situation.
I am now a frim believer of the search function. Thanks for your time. Mods, pls delete post if necessary.
Old Nov 5, 2009 | 12:06 PM
cbrahs's Avatar
Welcome abaord anyways!
Old Nov 5, 2009 | 12:10 PM
bansh-eman's Avatar
It should go away once you’re warmed up. I use the search button every day only to get 1500 posts of things completely irrelevant. I am definitely not the Goggle master!
Old Nov 19, 2009 | 01:49 PM
jfdid's Avatar
Just a quick response in case someone stumbles on this thread - if cold, the grid heater pre-heats before you start the truck. Once it's running, the grid heater will cycle on and off depending on intake temperature etc. You'll see the voltage drop(lights dim etc) for a few seconds, then back up to ~14 volts, then back down, repeats until the ECM is satisfied.
Heston_ram3500
Apr 16, 2007 10:33 PM
HotRodK
Feb 21, 2007 01:10 PM
Freight_Train
Jul 10, 2006 08:22 PM
psdctd
13
Feb 12, 2004 10:24 AM
psdctd
Nov 28, 2003 04:13 PM
