DTC P1757, can someone explain what is going on? PLEASE
a buddy of mine is at my house right now and he pulled the code P1757 off his computer a few minutes ago........as of last week it had no codes, but about a month ago he added the BDTD to the truck. the trucks a 04.5, basically stock performance wise except for the bully dog. can some exlpain what this could means?
P1757 Governor Pressure Above 3 PSI When Request Is 0 PSI
SYMPTOM
P1757-GOV PRESS ABOVE 3 PSI IN GEAR WITH 0 MPH
WHEN MONITORED
While the engine is running and the gear selector is in the Drive Position.
SET CONDITION
This code will set if the Governor Pressure is greater than 41.4 kPa (6 PSI) for 5 seconds while the gear selector is in the Drive position with the road speed equal to zero - six times during a drive cycle. The transmission oil temperature must be between 23-88 C (78-190 F) .
POSSIBLE CAUSES
Other transmission DTC's present
5-volt supply circuit open
5-volt supply circuit open inside the transmission
Oil burnt or oil pan has excessive debris
Governor pressure sensor
Valve body
ECM
Engine control module -5 volt supply
Intermittent wiring and connectors
THANK (53 ******) FOR THE INFO
WHEN MONITORED
SET CONDITION
POSSIBLE CAUSES
Valve body
ECM
Thanks guys im the one that had the problem. i think it was from me playing around and stalling the truck up. i cleared the code and it has not come back. i appreciate it.
calls
05-05-2004 10:17 AM
dcwm
28
05-14-2003 02:42 PM
