dash light problem
Old Jun 28, 2008 | 11:02 PM
Dwitt0187's Avatar
Question dash light problem
tonight i turned on my headlights but have now dash lights, radio lights or heater control lights, but all the guages, radio and heater controls work. has anyone had this problem. or any idea what would cause this problem i did check some of the fuses. but does anyone know what fuse controls the lights on teh dash.
thanks for the help
danny
Old Jun 29, 2008 | 09:21 AM
Dwitt0187's Avatar
bump.... anyone had this problem???
Old Jun 29, 2008 | 10:43 AM
DeTree's Avatar
usually the dash lights fuse is the same as the tail/parking lights fuse
Old Jun 29, 2008 | 04:16 PM
CatDiesel_762's Avatar
Do a search on here. This problem has been discussed before.
1. Try the fused mentioned above.
2. Check under your dash for loose wiring or ground connections.
3. Check any after-market electronics that you may have hardwired into the wiring near the dash.
4. You may have to replace you whole cluster. Sorry, Dealer Service only at this time.
Shawn
Old Jun 30, 2008 | 08:15 AM
Dwitt0187's Avatar
any more this morning?
Old Jun 30, 2008 | 09:29 AM
paroxysym's Avatar
um, check to make sure you didnt turn the dimmer **** all the way down accidentally? wow if none of the above worked- id double check with the dealer.
Old Jun 30, 2008 | 09:40 AM
cwgtex's Avatar
Arrow fuses
Rather than trying to hunt down which fuse is the right one to check, just check them all, it only takes a second for each fuse. Get a multi meter and put it on short test, which gives an audible tone if two points are electrically the same, such as two ends of a fuse. Open the fuse box and just run down the fuses, putting the multimeter leads on every fuse. Everyone should make the multimeter sound a tone. When you find one that doesn't, pull it out and you will probably be able to tell just by looking that it has blown. Get a replacement of the same amp rating (typically the same color). Unless you have major electrical problems, I'm willing to bet its just a fuse.
Old Jun 30, 2008 | 09:53 AM
Dwitt0187's Avatar
well i got to thinking about what was the last thing i did that couldve caused this and the only thing i can think is plug in our gooseneck but all the lights on the trailer worked properly and so did the lights on the truck but i didnt check to see if the dash lights were on and i didnt drive the truck at night for a couples after so never noticed them not working so i guess im going to have to go through and check all the fuses. i was just hoping that maybe some would have experienced this before and would know what fuse it was
thanks for all the help
danny
Old Jul 2, 2008 | 07:34 AM
Dwitt0187's Avatar
ok ive checked all the fuses under the hood does anyone know of any other fuses that i have missed because it think this is about to turn into a headacke i called the dealer and they told me to check the 3 amp fuse under the dash but the thing i cant find any 3 amp fuse under there so if anyone knows where it is at please tell me or send me a picture of it
danny
NoSparkplugs
17
May 17, 2009 10:36 PM
TGriffith
Dec 8, 2006 10:34 AM
johnny5.9
Oct 19, 2006 10:37 AM
TopGun
Apr 16, 2006 05:54 AM
megajoltman
Apr 13, 2006 02:58 PM
