cruise control
Old Dec 26, 2004 | 01:45 PM
Blue600's Avatar
cruise control
My CC quit working today. The cruise light comes on in the dash but the cruise control won't activate. Any ideas?
Thanks, Les
Old Dec 26, 2004 | 02:22 PM
big red psd cc's Avatar
Maybe the "set" button is sticking.....
Old Dec 26, 2004 | 02:27 PM
natstayl's Avatar
Perhaps the servo plunger has came loose from the throttle linkage?
Nat
Old Dec 26, 2004 | 03:42 PM
Buzzer's Avatar
Check your vacume pump which is right behind the passenger side battery to see if it is working.
Old Dec 26, 2004 | 03:43 PM
Geico266's Avatar
The CC servo valve is under the driver's side battery. Sometimes battery acid will eat up the plastic parts and cause a vacuum leak. The sooner you get rid of your lead acid batteries the less damage they will do.
I just replaced my CC servo. It would set, but not hold speed. The speed would slowly slip lower until it would not longer hold at all. Eventually, it would not work at all.
Did it fail slowly or all at once?
Old Dec 26, 2004 | 06:23 PM
Blue600's Avatar
Thanks for the replies. It happened all at once. I was just hoping it might be something I could take care of instead of going to the dealer.
Old Dec 26, 2004 | 06:36 PM
Geico266's Avatar
I would not mess with it if you are still under warranty. They can be a PITA to work on.
Old Dec 27, 2004 | 07:43 AM
Blue600's Avatar
Ya I'm under warranty, only 5300 miles on it.
Old Dec 27, 2004 | 08:16 AM
Artie04's Avatar
I had a problem with CC not holding and the Tech ended up talking with the STAR center as a strange status was showing up on the Speed Control panel when using the DRB III scanner. The electric vacuum pump was not working corectly. This part is is on special release and only with a code from the STAR support staff. Luckily they were able to over nited one from CA and the CC has been OK for two months now.
Old Dec 27, 2004 | 07:41 PM
DFD536's Avatar
Try checking your brake light switch... I had an older dodge, that the brake light was out of adjustment, and the brake lights would flash on occasion, making the cruise not work, as it thought i was hitting the brakes.
Just a thought, hope it helps
Dennis
Old Dec 28, 2004 | 08:13 AM
Blue600's Avatar
It's going to the dealer Friday.
Old Dec 31, 2004 | 11:37 AM
Blue600's Avatar
We had a bad snow storm, 3 feet in my yard. I make it to the dealer to have the cruise control fixed.........NO service techs make it in to work Now I'll have to make another trip to the dealer in the future
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
sam
Mar 31, 2003 09:04 PM
TexasDiesel
Dec 27, 2002 10:47 AM
