Can I pull some fuses to use as a temporary anti-theft tactic?
Old Feb 16, 2008 | 06:01 PM
NoSparkplugs's Avatar
Ok so I pick up my new (to me) truck on tuesday. I plan on using it to go on a snowmobile trip in BC and I'd like to make it semi-steal proof. I don't have the time at the moment to get an alarm system installed SO with that in mind, could I pull the fuses to the fuel system or starter to prevent the truck from starting. Or am I asking for potential problems if I forget I pulled said fuses and try firing it up (throw codes like a banshee?). The hotel we stay at has a locked and gated but I'd like to further ensure that should some lowlife doesn't swipe my new truck should he/she target it.
Any other ideas I could try? I plan on getting an alarm/remote starter installed on the truck soon. I worked/am working my tail off to buy this rig, last thing I need is some moron ripping it out of my possession.
Old Feb 16, 2008 | 06:06 PM
RRAMctd's Avatar
Check under the hood in the big fuse box. There is some large fuses in there I bet would get the job done. If there are some for the pump that would be my bet as to where they hide em.
Old Feb 16, 2008 | 08:09 PM
InfernoB's Avatar
Quick fix is to install a toggle switch between the "Switch" wire on your auxiliary solenoid to the starter.
Or even a switch to bypass the fuel solenoid. Make sure you get the correct amp switch though. If it burns out, then you will be the who got proofed.
Old Feb 17, 2008 | 12:30 PM
Dynocon's Avatar
Is there a starter relay you could pull?
Old Feb 17, 2008 | 06:52 PM
triplenickel's Avatar
I do it everytime I leave mine at the airport to go to work.
Old Feb 18, 2008 | 02:21 PM
DBLR's Avatar
What year is it as the 2006 up have a built in anti theft system so the engine does not run more then 30 second with out the proper key in it.
Jim5870
Jul 6, 2014 08:33 PM
SKATERHAULER
16
Feb 11, 2010 06:32 PM
Shovelhead
Jan 24, 2008 12:01 AM
handymantim
25
Jan 31, 2004 06:46 AM
GaCamper
Dec 1, 2003 08:59 PM
