A/C Compressor Safety valve opening?
I've been having problems with the A/C ever since I bought the truck. Thought I had a leak somewhere, so I put the dye in it and could not find anything. I took it to mechanic (local) and he went over the system with his Snap-On sniffer and could find no leaks. But he did say:
The fan clutch is not working, so there is not enough airflow through the condensor and the condensor is getting way too hot, causing extremely high pressure buildup, which is causing the safety valve on the compressor to open. This is how I'm losing freon.
Does this sound right? I thought that there was a (too) high pressure sensor that would prevent over-pressurization. He said he saw it spike up to almost 500 psi!!
Also, should the fan clutch be fully engaged whenever the A/C is on, regardless of engine temp?
03 2500 SLT, stock, 5 speed, quad cab, longbed
Last edited by brentbiely; May 1, 2009 at 10:20 PM. Reason: Left out some info....
The fan clutch is controled by the ECM. This is exactly why we have so many issues with the A/C systems on these trucks. I did a retrofit to my truck courtesy of BEMO. It has worked for 2 years with no issues. My truck has now leaked down again. My opinion the programming is not quite right causing the high spike. You will mainly see it with a cold engine. If you get going down the road before you turn the A/C on the spike is not as bad and you will not loose freon. Make sure you only have 2.00lbs of refrig. in the system, don't overcharge it with freon or oil. My next step this year is to put a electric fan on the front of the condenser (slim line 2" thick) with a thermostate control and A/C on control. This should stop the high pressure spike with a cold truck and in stop/go traffic when the fan dosen't come on. Their is no real fix for this. Guess I am going to have to make my own.
I've hauled a small trailer (1 ton), fairly regular, with my bed full of materials too, and I've never had the temp needle go much past 200, even on hot days. After digging thru the forums, I suspect the fan clutch is working OK. I wouldn't really know for sure unless I hooked up a scan tool that could turn the fan on manually.
My current plan is to only use the A/C once I get up and going, and turn it off in traffic, just to see how long the charge lasts. If I lose charge again then I'll have someone do an evacuation, check the amount of oil, then recharge. Sounds like I might need to install an electric fan as well....
Spooler, can you give more info on the BEMO retrofit?
Mine seems to work fine, even in the desert and city driving. Is there a reflash to make the fanclutch work better in A/C? Or maybe add a temp switch to the A/C compressor discharge line to bring on the fan when the A/C is on and the discharge gets hot enough? Craig
lovin1stgens
Aug 31, 2018 09:49 PM
WhoCares79
Jun 3, 2008 11:45 AM
Camarogenius
Jun 25, 2007 08:55 PM
bausman
Jul 29, 2005 07:54 AM
