Brake controller connector
Old Apr 12, 2004 | 08:17 AM
dcorneli's Avatar
I'm installing my camper brake controller in our new 2500. The connector under the dash is about as far left and up as it could be. It seems to be attached somehow in its current location. I need to be able to pull it down to connect my controller. I'm afraid to yank it down without knowing how it's being held in place.
Has anyone else pulled this connector down?
Thanks,
David
Old Apr 12, 2004 | 09:48 AM
bulabula's Avatar
Yeah, its a royal PIA. I think I released the nylon harness strap, but can't remember. It'll go in, don't be shy with it.
Old Apr 12, 2004 | 09:49 AM
wyosteve's Avatar
Someone on TDR mentioned that there is a plastic tie holding it on and you can cut it to move the connector. I haven't tried yet myself since my Prodigy has not arrived.
Old Apr 12, 2004 | 09:55 AM
dcorneli's Avatar
Yup, I saw the post about the tie wrap. I'm going to "go back in" tonight!
Thanks!
Old Sep 14, 2004 | 10:24 PM
azjeff's Avatar
After reading the posts, I expected to have a real deal of time finding the connection for my Prodigy on the '05 and thought 30 minutes would do it.
I got out the harness made by Tekonsha and saw that it had a blue connector for the vehicle end and looked under the dash and a blue connector was attached to the left side of the fuse box that was the same as the cable end. I plugged it in, removed 1 screw on the right side of the steering wheel and mounted the Prodigy cage to it, slid the cable through the cage and plugged it in. The lights came on and it worked when the trailer was hooked up to it. It really didn't take 3 minutes, I don't know when that hookup was started, but is sure is neat and easy. Jeff
Old Sep 15, 2004 | 11:30 AM
NJMurvin's Avatar
FYI, I yanked on mine and it pulled free fairly easily. The tie seems to be made of a zigzag material that breaks without much force applied. I tied everything off with new wire ties once it was hooked up.
I noticed on a TV commercial for the new 05 Ford SD, they're offering an in-dash brake controller from the factory. I wonder how good it is?
Neil
Old Sep 15, 2004 | 09:09 PM
SuperGewl's Avatar
Neil
Go trade your CTD in and let us know
Old Sep 16, 2004 | 10:39 AM
NJMurvin's Avatar
SuperGewl,
I said "they're offering an in-dash brake controller", not a "Cummins engine". In that case, I might consider it . . . but not for too long.
Neil
Busboy
21
Jun 10, 2011 11:39 AM
Justlooking
Mar 15, 2010 10:15 AM
kingofdodge7131
Jan 31, 2010 10:15 AM
tincan
Oct 19, 2007 10:50 AM
RHC
Oct 22, 2003 07:30 AM
