any way to get rid of the seat belt chime
had the dealer look into the computer and they couldnt undo it like the older trucks, i know my 06 there was a code with the key to disable it but cant seem to find that either, anyone know? mine is a 09.5 mega, thanks
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
the seat belt buckel under drivers seat is just a ground loop. the latch goes in and completes the ground. tap those 2 wires together to complete the ground. SRS system thinks seat belt is engaged 24/7
the key procedure only kills the chime. it does not do anything with the light. the procedure is in the owners manual on 06-newer trucks.
How to disable the chime is CLEARLY explained in the 2006 owners manual. I disabled both the chime and the light by jumping the two wires in the connector associated to the seat belt using a paper clip. Bent it so it would insert into the plug - kind of a squared-off 'U' - does a perfect job and can easily be removed. The plug is located at the seat base, easily accessed at the back of the seat.
CD
CD
I just went and disabled the chime. I am kind of concered with jumping the wires. I am not sure if this tells the trucks computer that it is ok to deploy the airbags thiking your seat is buckled or not. I never drive on the roads without my seat belt either way, but I still don't like the thought of bypassing something that could potentialy do alot of damage if something does happen.
i bought a used Bully Dog Triple dog downloader for $200 one of the features is that you can turn off the seat belt chime along with many other options like speedo recalibration for tire size and Performance level options
get in the truck shut the door...fasten the seatbelt turn on the key fasten and unfasten the seatbelt 3 times and it will "ding" and the dinger is disabled for an 06'
dtrkstan
11-03-2006 09:53 PM
ckennedy
10-24-2004 11:16 PM
339K&Counting
06-06-2004 12:13 AM
Lightman
10-27-2003 04:08 PM
