Adjusting Headlight Beam?
Old Nov 22, 2006 | 11:52 PM
Hohn2's Avatar
Since I have my truck lifted a bit, everyone thinks that I have my brights on when I just have the lows on. Is there any way to adjust the beams on these new headlamp assemblies? I am getting tired of brighting people to explain that I AM on low beam!
Old Nov 23, 2006 | 06:24 AM
2500's Avatar
ALL headlamps have adjustments. simply remove trim to locate.
assuming you don't have the high $$ beam alignment tools...
best way to aim headlamps is to find a dark level parking lot. back off 50feet or so, shine beam against wall to find aim points.
Old Nov 23, 2006 | 07:50 AM
MikeyB's Avatar
The up/down adjustment is located on the side of the headlight assembly right next to the grill. The hood needs to be open to adjust the lights.
MikeyB
Old Nov 23, 2006 | 10:01 AM
Hohn2's Avatar
Thanks guys! Will do that tomorrow!
Old Nov 23, 2006 | 11:20 AM
ptgarcia's Avatar
The adjuster is behind the little rubber seal on the headlight assembly. Pop the hood, fold the seal back, and use a T-15 Torx driver (I think, I can't remember exactly) to adjust. Well, thats how I did mine anyway!
Old Nov 23, 2006 | 11:38 AM
topless's Avatar
According to the manual, a 2" drop at 25 feet is the spec. Measure from the center of the bulb on a level surface.
Old Nov 25, 2006 | 06:58 PM
Robert373's Avatar
Thanks Ptgarcia. I had a look and couldn't find the adjusters. It was too cold out here today to take an extended look around.
I have to adjust mine down a bit also, since I lowered the back end, I have gotten lots of high beams.
Old Nov 25, 2006 | 07:28 PM
04ctd's Avatar
You need a T-20 Torx Bit to aim head & fog lites
i put it in a thread - got pushed down...will TTT it...
Old Nov 25, 2006 | 09:25 PM
Longhorn06's Avatar
Agree, and no trim to remove on an 06!
IPDiesel
Dec 16, 2010 04:25 PM
hopak
May 11, 2009 03:12 PM
tcb
25
Dec 20, 2004 01:25 AM
tv_larsen
May 7, 2004 05:03 AM
DeaconWayne
Oct 10, 2002 07:23 AM
