Adding Sirius Sportster to truck with sattelite radio already installed
I would like to mount my Sirius Sportster in my '06 which will be coming with the satellite already installed.
1. Is this possible?
2. If yes, how difficult?
3. Would it require purchasing more parts and at what cost?
The reason I want to do this is:
1. Sportster able to display more info. on screen.
2. I can still keep 1 Sirius account and move Sporster from car to home.
* My truck is still on order so I haven't seen the screen display on the stock radio. Can anybody comment on how much (or less) the stock radio display shows vs. the Sportster?
TIA
TIA
TIA
TIA
I just used the antenna that came with the Sportster and put it right behind the factory antenna. I put the sportster over the right side dash pocket.
I wired a plug behind the dash and plug it in. I ran a mini plug wire to the "aux" out on the stereo.
edited for spelling and grammar.
I also have the factory installed sirius in my 05.Can I buy a sportster and use my factory antenna in my truck,and then a separate docking station and the Sirius supplied antenna in my motorhome???
Thanks in advance
Thanks in advance
Maybe I didn't word that correctly.
I just don't want to use the add on sirius antenna on my truck,since it already has the factory 6 disc/sirius stereo system with factory installed antenna.On my motorhome,I'll use the whole sportster install kit,antenna and all....and switch the sportster unit from vehicle to vehicle.
Thanks
I just don't want to use the add on sirius antenna on my truck,since it already has the factory 6 disc/sirius stereo system with factory installed antenna.On my motorhome,I'll use the whole sportster install kit,antenna and all....and switch the sportster unit from vehicle to vehicle.Thanks
Yes you can do it. My 06 came with the free 1 yr sub. and I have the sportster replay. The last time I went camping I put the sportster in my truck so that I could listen to it in my TT. Yes, it is possible to have the sporster on in the truck and listen to it in the trailer. Make sure you have the FM att. hooked up that came with the unit, helps broadcast the signal better. And you can still tune the stock radio to your sporster with out having the stock radio picking up Sirius.
Snopczynski
Jan 15, 2009 01:00 PM
diesels4me
Jun 26, 2007 11:21 PM
tomm
Apr 26, 2006 06:55 PM
marka
Oct 3, 2005 12:20 AM
phildog
May 12, 2003 09:39 AM
