7 or 8 inch rims for dually?
Old Dec 31, 2002 | 09:01 AM
GO 4LO's Avatar
Does any company make a 17x7 or 17x8 rim for the '03 dually? The stockers are 17x6, right? Thanks.<br>Chris
Old Dec 31, 2002 | 09:23 AM
GO 4LO's Avatar
Re:7 or 8 inch rims for dually?
Also, one other question - has anyone ever used the 3&quot; &quot;dually conversion&quot; spacers between the rear wheels on each side of a stock dually? (in order to space the rims apart and fit wider tires)<br>Chris
Old Dec 31, 2002 | 12:15 PM
pappyman's Avatar
What are you trying to do with wide rims and spacers ??....are you trying to put on 33's on the rear if you are just get rims and put on a set of slicks...whats your point of needing wider rims ?? :
Old Dec 31, 2002 | 12:19 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Remember as you modify the established geometry of the rear wheels, you also reduce your weight carrying capacity.
Old Dec 31, 2002 | 01:00 PM
GO 4LO's Avatar
I want to fit a set of 37/12.50's, if I get an '03 instead of a 12V to play with. These are really going to be too wide for 6&quot; rims. I'd be getting the dually more for the additional stability while towing than for the additional payload capacity. Thanks.<br>Chris
Old Dec 31, 2002 | 01:16 PM
pappyman's Avatar
Well for spending $34-40000 on a new 03 just go buy a class 8 road tractor with super singles on the rear....and a big 500 HP cat with dual 8&quot; stacks...will probably cost you less
Old Dec 31, 2002 | 02:33 PM
Mopar_Mudder's Avatar
Ok I will be the one to ask. Why would you want to lift and put 37&quot; tires on a truck to tow with, makes no sence to me and I am into lifted off-road trucks. ???
Old Dec 31, 2002 | 02:37 PM
GO 4LO's Avatar
I just like 'em big . I'd probably go with 3&quot; lift up front and maybe 1&quot; in back - not enough to start having to worry about driveline angles or anything. I need aggressive enough tires on it to handle decent mud - primarily getting a 12k lb trailer back through the muck so I can unload the real rigs ;D .<br>Chris
Nov 9, 2004 01:35 PM
1Thom
15
Sep 23, 2003 03:05 PM
shaft
Sep 1, 2003 03:37 PM
bdaniel
May 6, 2003 04:43 PM
