2500 vs 3500
Originally posted by dcorneli
On the Dodge website I opened two windows and priced the same options on the 3500 and the 2500, and they came to within around $570, I think. Interestingly enough, I didn't have to manually select the CTD option on the 3500. It was specified from the get go.
The CTD is the base engine for the 3500. Standard Output according to Dodge's site two weeks ago, HO according to Edmunds.
About 2 months ago, I stopped at a dealer early one morning to see what was on the lot. The 48RE was a $1095 option on the 2500's, but only $695 on the 3500's. In addition, there was a $600 credit. The HO wasn't sold in MA, so the $600 credit was because it was an SO, and the $400 difference in tranny prices was because that's what the 6 speed (a mandatory option on the HO) would cost if it had the HO. If it had a 5 speed, there would have been a $400 credit.
Looks like this will all change once the 600's arrive.
There is one other difference between the 3500 and the 2500 besides the running lights and the springs. The 3500 srw comes with 10 ply tires which run @ 80 psi and the 2500 comes with 8 ply which run @ 50 psi. My nieghbor has a 2500 and I have a 3500 srw. We have both riden in each vehicles and both of us have said mine rode better with the stock tires. I just put on 315/70-17 KOs and we went out to dinner with the same nieghbors and his wife was impressed how much better in rides than before.
2500 vs 3500
I was all set to buy the 3500 instead of the 2500 because at the time the difference was ~$285 which I was told was the cost of the extra springs. I then called my insurance guy and asked what the difference in cost would be. The 3500 was $60 more every six months because he said the 3500 was classified as a commerical truck. I figured for the cost I could add the springs later if I needed them.
No... there are no differences between the '03/'04 H0 2500 and 3500 SRW besides the clearance lights and springs. They both utilize the same wheels and the same load range E tires with the same rating.
>which run @ 50 psi.
>which run @ 50 psi.
My 2500 came with E rated tires 265's. The 285 BFG T/A ko 's I put on are a D. BOTH have the same load rating. I'd rather have the D's anyway. Not too often I go to max weight (which would be 3195x4=12780). Oops hold on I can do that with my D tires too... I think if DC would let you order a SRW 3500 with no roof lites then they would sell more. I specifically told my dealer when he was searching for a truck not to find a 3500 because of the lights.
Forgive my ignorance, but do the clearance lights serve any practical purpose? The look would be a bit much for my use (non-commercial), but not a deal breaker if I decide the extra capacity is worth it to me.
Again, thanks for all the great discussion!
David
David
Yea, clearance lights offer an improved front signature which allows oncoming vehicles to better see your size. Ever notice that when you are towing during the day and the on coming traffic seams to move way away from the center line. I like that! I am installing full clearance lights as soon as I find em. I put them on my goosneck trailer already.
Nimrod
Nimrod
The 3500DRW has a different rear Axle then the 3500SRW or 2500. The 3500DRW uses a AAM 11.50 with a heaveier axle tube (thicker) so it has a higher weight rating. The spring are also different, as is the brakes.
Different spring and different Brake Calipers.....don't think so, but not sure.
I don't know for sure if the price is really that close. On the Dodge website I opened two windows and priced the same options on the 3500 and the 2500, and they came to within around $570, I think. Interestingly enough, I didn't have to manually select the CTD option on the 3500. It was specified from the get go.
But you're right about adding the overload springs later. It would be easy enough, but it'd be nice if the door sticker would tell the tale as well.
Thanks for all the input!
Originally posted by M829 APFSDS-T
Not exactly true. The 3500 and 2500 (HO or SO with Manual Trans) all have the 11.5 axle. Only 2500 with the 10.5 axle is an SO with AT.
Originally posted by y-knot
..., they buy a 2500.......and leave the big trucks for those who really need them.
The Boss Hog
(Happy with my not so big truck . . . )
Tree DR
12-01-2008 07:14 PM
dragginlx
15
03-09-2007 11:32 AM
ptgarcia
09-12-2006 06:04 PM
Patrick Campbell
03-20-2003 12:57 PM
11-01-2002 03:48 PM
