2001 Electrical Issue
Having an odd electrical issue on 2001 2500 4x4.
Multiple fuses blown. ASD relay was buzzing (replaced it). Alternator tests good. Batteries test good. Batteries not holding a charge more than a few hours. Any ideas?
I would check several things. You say the alternator tests good. It may put out voltage on a test but if the diodes are bad or have an issue it will charge but discharge when the truck is sitting and will sap the batteries in no time at all. I would double check the alt. You could simply unhook it and see if your batteries stay up. It may be good and you have a short else where.
On the fuse issue.............you seem to have a short somewhere. If multiple fuses are blown I would check to see if they all share something in common. Has there been any recent work on the truck that could lead you to a suspect area. Otherwise you need to check each circuit of the blown fuse to see where its shorting which is causing your blown fuse an or the current drain of your batteries.
47
47
wortnburger
Sep 20, 2014 10:40 PM
