06 rides too rough on freeway
Old 04-15-2007, 01:08 AM
SkiWaNOw's Avatar
My brother-in-law says his 06 is excessively bumpy when driving over expansion joints on the freeway in San Diego. His truck is totally stock except for a set of BFG alterains that are 315 wide. I suggested lowering air pressures to soften the ride if they are already toward the upper limit (although now that I think about it, raising pressures toward the upperr limit might help control some of the bouncing), consider looking for a softer set of shocks, and on the radical end of things, consider disconnecting the sway bars when not hauling or towing. Is there anything else that could be done?
Old 04-15-2007, 04:20 AM
Raspy's Avatar
Location: Smith Valley, NV (sometimes Redwood City, CA)
The shocks are already way too soft. The sway bar does not control bouncing, so that won't help.
Maybe he should just remember that he bought a big heavy duty truck, not a luxo car. How could a truck ride like a cloud and have big tires and do heavy work? It's a truck.
Wetspirit
Old 04-15-2007, 06:17 AM
t-boe's Avatar
Wetspirit is right. It's a heavy duty truck. It does ride nice for a 3/4 ton IMHO. He could swap to some bilsteins. That should help some. Disconnecting the swaybars won't help. If he really wants to change the ride get a suspension setup from Don Thuren, Carli Suspension, or Kore Performance. Those are in the order of my preference. Even if he does go that route, it's still a heavy duty truck.
Old 04-15-2007, 08:10 AM
mitternocht's Avatar
In my opinion these 3rd gen trucks are designed to run too smooth on the highway as it is. The Soccer mom/dad “urbanifacation” of these trucks makes them just about worthless in the snow or off-road. (Not to mention the front ends that bottom out.) The rear springs are too soft causing axel wrap and hopping.
By buddy has a ’99 similar to yours and has never had an issue in the snow or off-road, but then again his truck rides like a “real-truck.” too. Another buddy of mine had a ¾ ton truck from the 1980’s, that thing rode like crap until you had 1000 lbs ion the bed, but you could do anything with that beast. The 3rd gen trucks can be brought back from the urbanifacation, but it takes aftermarket parts and coin.
If he wants a nice ride tell him to take off those 315s to reduce the un-sprung weight.
Old 04-15-2007, 08:40 AM
Marine's Avatar
Tell him to put 1000-2000 pounds in the bed.
Old 04-15-2007, 08:43 AM
TurboTurd777's Avatar
with the kore leveling kit, will the truck sag after a few years?
Old 04-15-2007, 08:52 AM
t-boe's Avatar
Springs are only rated for so many cycles, so yes they probably will. They are quality springs and if they do it'll take a long time and probably won't sag that much to notice.
Old 04-15-2007, 08:53 AM
67guzzler's Avatar
"Turbo-Turd" --- Great name! Ha Ha Ha.....
Old 04-15-2007, 09:08 AM
donnee's Avatar
San Diego isnt the only area that has rough roads.
Anywhere is So Cal is that way.
I travel on the 101 and 118 and they both cause the truck to bounce and buck.
I keep reminding myself "you got a heavy truck"
Old 04-15-2007, 11:10 AM
FMB
FMB's Avatar
My wife won't let me drive in the #1 lane on 80 through Suisun/Cordilia area because of excessive bouncing.
Old 04-15-2007, 11:18 AM
lehall's Avatar
The crappy seats in the 06's
make it worse than they should too.
Old 04-15-2007, 12:32 PM
Fisherguy's Avatar
I bet it's a 1 ton short box, gee, sure rides rough!
Old 04-15-2007, 02:39 PM
Danderson's Avatar
Aftermarket suspension.
My new '07 beat me to death empty on the freeways here in San Diego. Conversely,adding my popup completely maxxed out the stock suspension,go figure! My signature says what I went with. All the manufacturers offer better front coils and minipaks for the rear. Research it and go with what you want.
Old 04-15-2007, 03:11 PM
C Schomer's Avatar
I cut the ends off of the bottom OLs so now they are just spacers and added bags. I wanted bags anyway and the truck doesn't need OLs AND bags. That helped a lot! Craig
Old 04-15-2007, 03:28 PM
RollOver Pete's Avatar
Right lanes are usually smother..
Quick Reply: 06 rides too rough on freeway
