06' 3500 MegaCab Vent dial switch not working
Anybody ever have a problem with the vent dial switch not working ?? i just noticed that it seems to not be working. I rotate the dial and nothing happens. I have a little AC air coming out of the vents but I can hear a whole lot of action happening behind the dash and not much air for it.
I believe there is a TSB out for the rear vent related to a rod that becomes disconnected behind the dash supposedly you can see it from the passenger side. Probably something similar but take it into the dealer for the easiest solution.
most likely a broken blend door, it is unfortunately a common occurence. I had it happen on my 05 but have read several posts on the 06's having the same issue. The entire dash has to come off. What a PITA.
Thats funny I noticed mine doing the same thing this past week
lot of noise in the dash like the blowers going but hardly any output at the vents...
I figured my door broke?????I also notice the sound does not change when I rotate the **** to recycle.....usually it gets a lot louder and more out put at the vents.......
lot of noise in the dash like the blowers going but hardly any output at the vents...I figured my door broke?????I also notice the sound does not change when I rotate the **** to recycle.....usually it gets a lot louder and more out put at the vents.......
Has anyone had problems with the A/C cooling the truck. Yesterday I turned on the A/C and fairly quickly both vents on the drivers side of the Radio were blowing cold air, but the vent to right of the radio, was blowing hot air?!
What's up with that???
seems laramies have this problem...something to do with the blend door??
Sleigher
May 4, 2017 02:12 PM
97catintenn
Aug 7, 2009 08:23 PM
bimmerd00d
15
Nov 15, 2006 09:11 PM
ptgarcia
Sep 12, 2006 06:04 PM
