3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
what year 5.9 aftermarket exhaust will fit the 6.7?
Old Apr 26, 2009 | 04:48 PM
wesboyd585's Avatar
Old Apr 26, 2009 | 10:06 PM
'strokeThis_'07's Avatar
04.5-07 will bolt right up. Only one hanger may need tweaked or moved
Old Apr 30, 2009 | 11:30 PM
KNUCKLEMOVER's Avatar
What Would The Purpose Of Doing This?
An Option To Not Having To Do The Deletes?
Old May 1, 2009 | 06:57 PM
Putting on the 04.5-07 exhaust would be doing deletes, as those trucks dont have the DPF and the cat in the downpipe...
Old May 1, 2009 | 08:52 PM
Blake Clark's Avatar
Quick question, I have the H and S stage two with the EJA, all 4 inch, but if i wanted to go 5 inch I could use a kit for an 07 5.9. What would have to be done with the 02 sensors, do they not have to be installed in the pipe or does the Edge take care of that with clearing the codes on start up. Just worried cause I wouldnt wanna put my truck in limp mode. 5 inch systems for 06 to 07 are way cheaper than for my 08. Thanks in advance.
Old May 4, 2009 | 09:10 AM
ram 2500's Avatar
NOT-CORECT the after market exaust for the 04.5-07 from most mfg's are just a cat back system
Old May 4, 2009 | 02:45 PM
Hired Gun's Avatar
I just ordered an 07 Magnaflow Turbo Back 5 inch for a 5.9 to put on my 6.7. I am going to run it with my Smarty and do the EGR delete as well.
Old May 4, 2009 | 03:47 PM
Cat-back wont even fit with the DPF in place...so it is correct Unless you hack it up, but you can get DPF back for the 6.7 so there really isnt much point
If somebody asks about the earlier exhaust fitting the 6.7, you can only do a turbo back, which most, if not all, manufacturers also offer.
You could put a stock 04.5-07 exhaust on, cat and all, but that wasnt part of the question...or piece together a stock to cat then an aftermarket cat-back, but what would be the sense in that?
Old May 5, 2009 | 02:41 PM
BroncoHound's Avatar
You would need to weld bungs for your o2 sensors to the 5" TBE. Any muffler shop will have o2 sensor bungs and they are a standard size. They should be able to weld them on for you for $15 or so. You MUST have the o2 sensors in place unless you are running a Smarty or XRT. The Juice won't clear the codes for o2 sensors being removed.
Old May 5, 2009 | 06:48 PM
wesboyd585's Avatar
found me a 5" tbe for $289 shipped!!!
horsinaround
Apr 14, 2012 06:35 PM
trophystock
Jul 16, 2006 11:00 AM
06Cummins
Feb 7, 2006 03:30 PM
