Smarty REVO Upgrade Procedure Help...
Can anyone help me upgrade the smarty S67 for the DPF delete and the program to eliminate the extra injection on the exhaust stroke. This is not my tuner or truck so I have no clue where to begin!
I have tried searching threads, but havent found any concrete steps.
I have been to MADS site, and downloaded their .7z REVO program and the SmartyUSB.exe and the CDM 2.04.16.zip driver , but I cannot get the 7-zip program to download from the website... Can anyone help me out.
Thank you for any help.
There is a not alot of clear directions on the site..
1. Download the .7z file to your computer from Mads. I keep a separate Smarty directory on my machine with R15 as a separate folder.
2. Unzip the .7z file into that directory. You will have to download and install the 7zip program on your computer.
3. The instructions on the USB install pages help you with connecting your Smarty to your computer and installing the appropriate driver.
4. Run the SmartyUSB.exe program with the Smarty connected to your computer. Pick the File - Open and select the file you want to load, IE. S67V611AR15ME.Smt Hit send and wait about 15 minutes to load.
Hope that helps.
Hope that helps.
Are you having problems with the compression software download and install it sounds?
Try this link, it should be very easy to download and install per the directions.
http://www.7-zip.org/
Then is a matter of unzipping to the MADS file to the appropriate directory and then telling the USB program where that file is once your unit is connected to the computer.
Spooler
13
Apr 12, 2009 12:55 PM
rallydriver
Nov 1, 2008 12:41 PM
jmccart
Jun 23, 2008 11:11 AM
bigwheels94
Jun 4, 2008 09:47 AM
zack birge
May 11, 2008 09:57 PM
