3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Questions
Old Feb 24, 2013 | 09:36 PM
FruitaCrawler's Avatar
Questions
i finally pulled the trigger on the delete parts for my 07.5 cummins. I know that with the smarty you have to leave the EGR valve actuator plugged in. so for those of you that have done the full style deletes where and how did you secure that motor out of the way if you have pictures that would be helpful. also i need to get my hands on the correct delete file for a smarty jr. thaks in advance for the help and advice
Old Feb 25, 2013 | 08:08 AM
Jim W's Avatar
See this photo the EGR valve actuator is tied wrapped to the underside of the hoses in the photo.
Jim W.
Old Feb 25, 2013 | 04:43 PM
xcc_rider's Avatar
Ok, you have a 07.5. Chassis cab or truck? Smarty Sr or Jr?
Go to the cumminsforum, 07.5-09 performance thread and look at the first post for instructions.
The tunes for your year model and smarty jr have dissappeared, but I will try and upload them tönight.
Old Feb 25, 2013 | 10:29 PM
sorry i should have said that. It as a truck and i will be running a smarty jr.
Old Feb 25, 2013 | 11:54 PM
robby t's Avatar
you can secure the actuator motor to the lip of the battery box..run two screws through the holes on the egr motor to the battery box..drill to small holes...mounts up nice.....
Old Feb 26, 2013 | 12:36 AM
xcc_rider's Avatar
The file you need is SJ67v606E_DRM01K.7z for the zipped version or the already unzipped one ends with .smt.
Same location, first thread in this section. Follow the instructions and log into filebox, select file and open the 2007.5-2009 directory. The file you want is there.
Download it, unzip it if you need to and load it on the smartyjr
Old Feb 26, 2013 | 09:08 AM
thanks for all the help. hopefully my tuner and ezhaust will show up today to i can start installing parts and get this thing running like it should
Turbocrazy
Feb 25, 2013 04:40 PM
popeye4wheeler
Jan 30, 2011 06:24 PM
Clucker
22
Sep 24, 2009 09:34 PM
GR40RCapri
Oct 30, 2007 09:37 AM
gman07
Apr 15, 2006 08:32 PM
