3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Question about timing
Old 09-04-2017, 03:31 PM
Doowiggey's Avatar
After installing Mini Maxx w/trans tune and fully deleting my truck I have a rattling sound when accelerating. Almost sounds like detonation on older gas engine. Buddy tells me I should set timing to 2 and run tow power level to cure the rattling.
What do you all think? Truck is a 09 with auto trans and I only run stock power setting because I don't want to damage my trans or blow head gasket. I am happy with power at stock setting, more concerned about trucks components lasting as long as possible, and mpg.
Any reccomendations on what my settings should be?
Old 09-04-2017, 10:05 PM
Doowiggey's Avatar
No one wants to help an old man out with this new technology? Last diesel I had was a mid 80s 6.2. All mechanical no computers, much easier to work on.
Old 09-05-2017, 06:54 AM
saggonwaggon91's Avatar
You can try to up the timing and see what it does
Old 09-07-2017, 08:42 AM
nkennedy's Avatar
I have same truck as you. 2009 with 6.7 & 68RFE. I went with the defaults thru the install of the min max, but I run the tow tune all the time. My mechanic said it wouldn't hurt it, and so far EGT's & trans temps confirm this. Diesel's do rattle, so can't help you there.
Old 09-07-2017, 11:34 AM
BILTIT's Avatar
Usually the rattle is from additional timing, i notice this with my smarty and a cold engine. Try reducing timing to remove rattle.
Old 09-09-2017, 11:58 AM
Doowiggey's Avatar
Thanks everyone. Set timing to 2, and running tow. Rattling gone with more power. Just wanted to make sure I wasn't going to prematurely wear any components out doing this.
Honkylips
10-15-2007 07:07 AM
GR40RCapri
06-25-2006 12:53 AM
West Coast
03-26-2006 11:09 AM
RonP
02-24-2006 02:12 PM
redhornet
05-28-2004 06:06 PM
Quick Reply: Question about timing
