Programmer only?
Programmer only?
1st of all can you run just the programmer only, with no deletes, I'm assuming you can. My question is do you get the benifits, more power, more mpg, more HP, that they all seem to claim? Also if you run just the programmer, and you have issue under warranty, can you go back to stock and have it fixed at the dealer with out a footprint of ever having a programmer installed.
You can run the Smarty 67 with the ME or without. Meaning you can run the program with or without the deletes but need the right downloaded program for what you want (free download).
I don't think any of the programmers are undetectable and will leave some kind of footprint depending on how hard one looks.
I am very happy with the gains in power and economy.
Like stated above, you can, but the delete offer better gains all around for power, MPG's, and longevity.
No setup is undetectable, even the add on ECM systems like Edge. If they want to find it, they can dig until they do.
So you guys with the deletes, what do you do when you get a flash update from dodge, hook everything back up, or ignore the notice?
On a full delete, do you do just the egr, or the cooler part also, and whats the differance.
some one said 1400 for the deletes, or around that, the pipe and egr stuff is pretty cheap, so its the controllor that cost the most?
Thanks
