Programmer only?
That's pretty much it! Mega style takes less time and $, but is not nearly as good looking as studly as Blake style.
Just so you know. All you need is a short straight delete pipe between the CAT and muffler for the exhaust and to do the simple and basic disconnections shown in the MADS instructions for the S67ME. Nothing more.
More power to you if you can save up and achieve the rest and clean it up nicely and not worry about going back!
Wife gave me the go-ahead on the parts.
What about a air system, whos got good luck with what brand? Thanks
(It is recommended that you run an H&S Fuel Rail Plug or Fuel Rail Shim Kit when installing an XRT on a 6.7L Cummins)
I copied that from the xrt Tuner from HS, is that only for when it is set in the 175 HP setting?
another question, is this tuner (XRT) the smarty
Thats what I'm going to do, just the delete pipe, keep my muffler and tailpipe, for now. The delete pipe for 214.00 from HS, does that delete the cat also? I'm not going to remove the throttle valve and cooler, just unplug them. If I just unplug the cooler, what do I get, just the egr delete, or do I get the egr/cooler delete kit?
You don't need any physical "deletes". Disable is probably a better word. MADS shows the disconnects and how to remove the pluger from the EGR which is 5 minutes and you are disabled EGR wise. You just have "vestiges" at that point.
I have an S & B CAI, but there are many good ones out there.
XRT is from H&S and people like it. Smarty is from MADS and people love it. I certainly do, and suggest the Smarty. They are different programmers. Both good.
No sir, the CAT stays in the system. It is the NOX and DPF cans that have all the connections and get deleted.
Mega can correct me if Im wrong, but I believe that when you pull the EGR plunger it disables the system and you should not need to plug the crossover tube.
However, seeing how easy it is to remove/replace it may not be a bad idea to plug it. A freeze plug with a bolt welded/screwed to it seems to be the most common method.
The cooler just needs to be unplugged.
It is all so easy and basic when I read Marco's instructions I was sold on doing doing the ME. I originally bought the non-ME version.
I took off the crossover tube and put a freeze plug in the housing for good measure. I also wanted to see how dirty that system was after only 3K miles? It looked like a chimney. I put the tube back on over the plug (doorman #555-020 with a bolt in the middle and nut on either side) just like original. Removing the plunger is all one phyiscally needs to do such that the butterfly is not activated. Also, Smarty commands the EGR control to zero anyway.
thanks for the info, getting excited now!!
Yes, it is cool. If I ever have to revert back temporarily, afterwards I can still run the Smarty regular as it is a relatively easy download to the unit and truck until I have the opportunity to disable again and then upload the ME...
mega, where did you say you ordered all your parts, I'll probably go your route, leave the cat on. Is it a little louder?
Back when it was hard to even find a delete pipe, I was able to get a Pro-Flow with 1 bung in it for some reason. I put a cut down bolt in it to plug. I think I found the pipe at RPMOutlet.com. Cheapest route is to go to a mufler shop and have them weld a pipe to the flange with 1 hanger. That is really all it is. Freeze plug came from Kragen. Smarty came from right here at the DTR Store!
Honestly? I don't think it is much louder exhaust wise, but you can hear the exhaust brake more during warm-up for sure when it is cold.
I put a CAI on and like the sound of the turbo over any exhaust. Reminds me of being on an airplane...
I too love the sound of the turbo with a CAI. I have aFe Stage II and it sure sings.
The single bung is because the 1st O2 sensor is forward of the delete pipe flange in the down pipe. If you leave the cat in place, the first sensor can stay in the DP. Just unplug the sensor to use the ME version.
