Just the programmer?
I've read enough of these threads that I understand the delates, air filter, exhaust, etc. are the way to go to make power. Simply, what gains can be expected with just the addition of a programmer? Would it hurt anything, other than my wallet, to just go with a programmer? I dont race, mud, or show off, I just go to town a couple times a week and tow my toy hauler a few times a year to the dunes. Thanks.
At most I would think 40-50 hp would be all you want. I have close to 400hp 800ft lbs on my '03. It is enough for me. Just a programmer should do that. With the new HO I believe all cummins did was new programming and a fluid filled vibration damper.
This is from the Ram Zone and I quote.
"Our Ram engineers just didn’t stop at the engine. Additional upgrades include a new power train control module with a revised performance calibration that allows the six-cylinder Cummins Diesel to achieve peak power at a more desirable rpm range. The automatic transmission also has a new higher-rated torque converter to take advantage of the increase torque and better integration for improved towing capabilities on various road conditions. Also, the High-Output Cummins has a revised crankshaft damper that will reduce engine noise and vibration throughout the interior of the Ram.
Our engineers also upgraded the axle on the 3500 Heavy Duty dually models with an improved 4.10 axle gear ratio that will include stronger helical gears and upgraded bearings along with a finned aluminum differential cover that will dissipate heat. To moderate the transmission fluid temperature in severe duty towing situations, we also designed a new engine-mounted, water-to-oil transmission cooler."
Jim W.
Then if you decide to delete later you can down load the ME software to reprogram your truck with the S67 Smarty. This is the same unit that will use either the ME programming or US emission programming version of software.
I would also recommend gages whenever you add a programmer to any truck, just for peace of mind.
Jim W.
OK, so for a guy like me that may want to add a programmer now, and possibly consider deletes in the future, what would be a decent programmer? I just want a little extra peace of mind, in the form of power, as I tow up hills, but I dont want to open Pandoras box with extreme exhaust temps or any other problems that may be associated with my tinkering and changing things.
You can go with a Smarty Jr or Smarty S67 or any of the H&S line of tuners. Those would get you started and if you want to delete later you can download the delete tunes for the Smarty's. The H&S come with both tunes loaded for delete and non delete. Hope this helps you.
You can get either brand thru the DTR store.
Erik@LCD
30
03-25-2009 02:07 PM
NHRedneck
15
12-08-2006 09:02 AM
Common
12-06-2006 11:18 AM
Igor
11-25-2006 02:27 PM
