Just checking if this is "gelling" or just cold combustion...
Old Dec 6, 2006 | 07:35 AM
Common's Avatar
I jumped in the truck the other morning @ 15* F outside...
It ran weird about 1/5 of a mile... when the turbo spooled, smoke (bluish gray) would come out of the tailpipe.
I didn't allow the engine to warm up at all because I was running late, but after it warmed up a bit, 4 minutes, all was clear...
Old Dec 6, 2006 | 07:37 AM
Common's Avatar
Dude, your rep should be higher because you are awesome!
Old Dec 6, 2006 | 08:23 AM
jlipskoc's Avatar
Sounds like cold cylinders. Did you have it plugged in?
If you haven't advanced the timing any, I would, it really helps when its cold.
Old Dec 6, 2006 | 08:27 AM
madhat's Avatar
Administrator/Jarhead
Sounds like it was just cold. Jelled fuel would cause the the truck not to run at all, b/c little or no fuel would get to the injectors.
Old Dec 6, 2006 | 10:00 AM
Common's Avatar
Thanks homies...
I havent plugged the truck in yet...
Old Dec 6, 2006 | 10:20 AM
Forrest Nearing's Avatar
yeah, she was just cold... if you haven't bumped timing, it can help this some
Old Dec 6, 2006 | 11:18 AM
jlipskoc's Avatar
I'd personally get a timer set to 3-4 hrs ahead of when you leave, and plug it in anytime it falls below freezing.
For me, easier starting, less strain on batteries and having some heat in the engine, snow melted windows really is worth any cost in electricity.
Everyone else is right though, timing advanced really helps when cold, not to mention, during the summer lower egts and better fuel economy.
linetrash75
Dec 30, 2009 06:33 PM
NotEnufGarage
22
Jan 28, 2009 04:59 PM
satburn
13
Mar 16, 2007 12:37 PM
Artsi_L
Dec 25, 2005 10:30 AM
Commatoze
Apr 28, 2004 08:04 PM
