3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Help, P244A code
Old Aug 27, 2014 | 08:23 AM
Jeepman71's Avatar
I can sleep now, my Smarty is safe.
Help, P244A code
I have been running a Smarty Jr. DPF delete Mega (Cali) style for the last two years. My time has expired and I need to do emissions. I put the DPF and Nox back in and set the tuner back to stock. I had two codes come up, first was for the throttle and second was for the cooler. I cleared these and all was good. I drove the truck about ten miles and the CIL came on again along with the overhead saying the "Catalyst Is Full Get Service". I checked the code and it was P244A Low DPF Pressure. I cleared it and drove for about ten miles and it came up again. I checked to make sure all the connectors are plugged in and one of the pressure sensor tubes didn't slip off but found nothing. Everything was fine when I removed the system two years ago. Short of a spider making a web in one of the pressure tubes I am lost.
Thanks for your help
Jim
Old Aug 27, 2014 | 12:55 PM
mega-engr's Avatar
"California Style"
Try to unplug the connectors and make sure they are clean on both sides. Spray with contact cleaner, put some dielectric grease and try again to make sure all connections are made. I would try reloading the software as well.
Old Aug 27, 2014 | 01:27 PM
Jeepman71's Avatar
Thanks for the reply mega-engr. I will pull the pressure lines and blow air through them and take your advice on the contacts. It seems that I may be missing a connection but I found three in the NOX/DPF section and two on the down pipe. I believe that is all there should be.
Jim
Old Aug 27, 2014 | 02:20 PM
mega-engr's Avatar
"California Style"
Double check the connect to the throttle valve and EGR cooler under the hood too.
Old Aug 27, 2014 | 06:36 PM
Jeepman71's Avatar
I cleared the code when I got to work this morning. Left work and headed home this afternoon and expected the CIL to come on any minute. My normal commute is five miles. I drove nearly forty miles and the light never came on. Here's hoping.
coope3
Feb 21, 2009 04:49 PM
kenny1987
Jan 24, 2008 01:19 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
