3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Front end too low.... Need suggestions on new coils
Old Mar 3, 2011 | 07:28 AM
Tiara3100's Avatar
I have a 2009 Mega Cab 2500 4X4 that needs some lift in the front end. I have looked at spacers and new coils, and I have decided to go with new coil springs.
I would like to bring the front end up about 2", but I need a coil spring that will carry the weight of a 850# plow and not jar my filings out on every bump.
So, I am looking for suggestions..... Thanks.
Old Mar 3, 2011 | 09:13 AM
singleturnout's Avatar
I would look at these http://lorenzindustries.com/products_coils.html
Old Mar 3, 2011 | 02:18 PM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
Also check out Don Thuren's 3" coils. Thuren Fabrication. He has excellent products
Old Mar 3, 2011 | 08:22 PM
greybeard's Avatar
What plow setup are you using? The reason I ask is my most manufacturers a have set up height for the push frame from ground so that the plow will stay even with the ground. My is 11 3/4 -12". With air cells the front drops less than an inch. Plow weighs 985lbs. They carry it well and with both spacers it sits well. IMHO
Old Mar 4, 2011 | 07:01 AM
Tiara3100's Avatar
I will be using a Western "Wide out" plow. But I'm not worried about the frame height of the plow as I will have to modify the frame anyway due to the fact that I run oversized 315 tires. As they say "Have Plasma Cutter and Welder, will travel".
LanceD
Oct 5, 2010 05:00 AM
mstep3
44
Jan 18, 2010 09:01 AM
Moobesor
Feb 23, 2008 09:57 AM
More Power
13
Dec 26, 2006 08:57 PM
v8440
14
Sep 7, 2005 08:39 PM
