3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
dimensions for dpf pipe flange
Old Apr 7, 2011 | 09:15 PM
Blacksunshine's Avatar
anyone know the size and bolt spacing for the dpf pipe, am building my own and dont want to take appart twice. any info would be great, being lazy i guess
Old Apr 8, 2011 | 02:10 PM
JCMINIS's Avatar
Use a thin piece of cardboard with a 4" hole, slit it slip it over pipe and trace out ? Thats how I was going to do mine...Just havent yet.
Old Apr 9, 2011 | 07:14 PM
Navy7797's Avatar
flange
I have several flanges that were cut on a lazer. I made my delete pipe with one of them. I just used a new gasket to pattern the flange. Used 3/8ths bolts. Got the 4" pipe a Napa. New gasket was 15 bucks at the dealer. The old one was kinda stuck to the pipe so I left it there for later use if needed.
Good luck, I also picked up 4mpg after deletes. No regen
Old Apr 10, 2011 | 06:14 PM
I'm laid off and bored right now, trucks in body shop, thanx but i'll just take it apart when it's back
Old Apr 11, 2011 | 08:30 AM
cbrahs's Avatar
heres a novel idea
go buy a gasket and there ya go. you will need one anyways if you are building a bolt on delete pipe. save ya a lot of trouble and you can start making the flange while waiting for the truck to get out of the bodyshop.
Old Apr 12, 2011 | 12:24 PM
hell of an idea, guess I'm not the sharpest tool in the shed. thanx
Old Apr 14, 2011 | 09:28 PM
gdafoe's Avatar
Navy, Did you use a straight pipe or did you have to bend it to get it to fit up right? How about hangars ? looks like there are a couple hangars now, but with all that weight gone are hangars still needed on the replacement pipe? Thinking about making my own as well as you can see. I see you are in AZ as well I'm about 12 South of Wickenburg how about you?
Old Apr 21, 2011 | 07:42 PM
XLR8R's Avatar
Chris, you always take the easy way out - when I get as old as you I'm gonna "work smarter not harder" too!
Old May 1, 2011 | 11:33 AM
Navy7797's Avatar
Late responce
Sorry I took so long to respond, been out of town. I used straight pipe and no hangers, the pipe is lite. I have a delete pipe here in my garage if you want to buy it $100. plus shipping. I'm located in Vail AZ just south of Tucson.
Old May 6, 2011 | 07:18 PM
gdafoe's Avatar
Thanks for the reply. Decided to order one. Installed and working....
mhuppertz
Mar 17, 2011 07:40 PM
mattmanj2001
Dec 11, 2010 07:33 AM
jklidy
Mar 11, 2010 08:52 AM
Txwelder
Jan 17, 2008 05:29 AM
magnusrw
Jan 28, 2006 09:15 PM
