3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Auto On Exhaust Brake Mod
Old Oct 30, 2010 | 01:19 PM
  #46
Aaron4x4's Avatar
Just did my truck thanks for the info it works perfectly!
Old Oct 30, 2010 | 01:46 PM
  #47
Colo_River_Ram's Avatar
With age comes the cage
C&C's comes with EB On/Off as per your last setting prior to shutting off.. This is a dealer flash to enable as well for non C&C's (that is if your dealer can read the instructions)
Mine stays on all of the time.. ('cept) for ice driving I agree on the auto on/off tow haul option
Old Nov 19, 2010 | 12:48 PM
  #48
txpig's Avatar
I completed this mod alittle over a year ago, and I love it.. I'd really like to do the same thing to tow/haul switch!
Old Nov 20, 2010 | 07:23 PM
  #49
Shadower's Avatar
Installed today with the relay from O'reillys part# r3177.
I didn't think it worked at first because I turned the key to the 'on' position and the EB light wasn't illuminated. Once I started the truck the light came on.
Thanks for a great mod!
Michael
Old May 3, 2011 | 06:48 PM
  #50
Bullet112233's Avatar
Does anyone know if this will work on the 4th gen truck?
Old May 3, 2011 | 07:57 PM
  #51
txfiremedic's Avatar
Not a 100% sure, but I suspect it would.
Old May 3, 2011 | 07:58 PM
  #52
Blake Clark's Avatar
Actually there was a thread where someone tried and it will not work, the entire panel of switches are all connected on a common board, no individual wire to splice into.
Old May 3, 2011 | 08:07 PM
  #53
Thanks for the info Blake!!!
Old May 6, 2011 | 12:52 PM
  #54
ejc252's Avatar
Just did this to my truck Yesterday. Love not having to press the button now when I get in it.
Old May 20, 2011 | 10:13 AM
  #55
Jaxom's Avatar
I'd like to read that thread. Searched, but didn't find it.
Old Sep 3, 2011 | 05:57 AM
  #56
rcoleman58's Avatar
2010's have a different setup you have a power wire coming into plug and three wires coming out one for four way flasher one for tpms and one for eb.using wire for eb wil blow fuse will take someone with more tech smarts than me to figure out
Old Feb 10, 2012 | 02:50 AM
  #57
IsItFast's Avatar
Installed this last month and love it.
One issue that I don't know if could be done via some rewiring. I have factory remote start and the brake won't come on until the key is turned on. Some accessories work when remote started but no with no key turned on...unfortunately the brake isn't one of them.
Is there an easy fix for this? Would be nice if the brake could help the truck warm up a little quicker in the winter.
Old Feb 10, 2012 | 07:06 AM
  #58
Shouldn't need to, if it's cold enough outside it will automatically engage the exhaust brake to help with the warm up.
Old Feb 10, 2012 | 12:33 PM
  #59
clarson80's Avatar
If it's cold enough, the engine will idle up to about 1,000 rpm, but the exhaust brake won't come on until the button is pressed. (on a stock pickup)
Old Feb 10, 2012 | 03:13 PM
  #60
IsItFast's Avatar
I guess I haven't made myself clear. The exhaust brake is an accessory that won't come on UNTIL you turn the key on. It is plenty cold and the exhaust brake comes on instantly as soon as the key is turned on (after the truck has been remote started). But with the truck running by remote start the exhaust brake is always off. Doesn't matter if you hit the button or not, it just won't come on since there isn't power to that accessory.
jmccart
Dec 19, 2007 12:49 AM
jamesbfishin
Jul 7, 2007 08:25 PM
wap
14
Apr 23, 2007 06:46 PM
DCinTX
Mar 18, 2007 11:00 PM
RAMV
Jul 14, 2004 12:08 PM
