wow!!!!!
Old Dec 21, 2006 | 12:31 PM
goodeyesniper75's Avatar
wow!!!!!
let me tell you a lil' somthin about smoke....crazy larry and xzillerator=storm cloud localized behind the truck.....a lot of power also
Old Dec 21, 2006 | 12:36 PM
dodgezilla04's Avatar
whoooo hooooo. good-bye ozone layer, goodeye is having fun
same thing happens with my smarty and race box too.
Old Dec 21, 2006 | 12:37 PM
haloman's Avatar
I would say really high EGTs really quick too.
Old Dec 21, 2006 | 01:54 PM
Should I Worry Bout Rail Pressure
Old Dec 21, 2006 | 02:13 PM
morkable's Avatar
i dont think so yet...... but definately egt
Kevin
Old Dec 21, 2006 | 02:25 PM
Hillbilly Delux's Avatar
Hey, i care about the ozone, i try'n only apply smoke to the front of following ricers thata way they can inhale it and filter it out
Old Dec 21, 2006 | 05:23 PM
is there anything i should worry about braking at all?
Old Dec 21, 2006 | 05:36 PM
Patriot2500's Avatar
The bank with some speeding tickets!!!
Congrats on the new power, should make a difference next week.
Old Dec 21, 2006 | 06:40 PM
rockittboy's Avatar
if he shouldnt worry about rail pressure with that combo...why, it i suddenly go to WOT with my bullydog triple on extreme, do i get a POP out the tailpipe? only thing i can think of is that im sucking the fuel rail dry...thoughts?
Old Dec 21, 2006 | 10:56 PM
qzilla's Avatar
When you add duration you typically lower the rail pressure. So if you add pressure back to it you are still adding pressure but actually less than the pressure adding product by itself.
Also typically duration and lack of pressure causes the rail to run dry. Your popping could be from too much duration and or a timing problem but, it is most likely not pressure related.
rbrettctd
Nov 11, 2008 01:42 PM
roadgeneral
Oct 17, 2007 06:54 PM
Shawn.L.Turbo
Jul 16, 2007 06:21 PM
getblown5.9
Dec 18, 2005 08:28 PM
