Would AERO4040xl raise EGTS? worse than stocky
Old Feb 3, 2008 | 11:50 AM
sallyman1's Avatar
By now you have all heard that i have a egt issue with my edge juice attitude. I can easily hit 1300 on level 1. My question is that is the aero the culprit. Lots say that it is. I deleted my cat and stock muffler and put the aero4040 where the cat was. Did I increase back pressure by doing this? should i put stock muffler back on to lower egts? Sounds like the stock muffler lowers egts by the sound of things?
Old Feb 3, 2008 | 11:55 AM
cbrahs's Avatar
i have never heard of freeing up exhaust flow increasing EGT's. I could be wrong but you did not increase backpressure. I have 5" turbo back (everything gone), have a 24" long 5"in/out resonator with stacks and my EGT's rarely go above 1200 with the smarty.
Old Feb 3, 2008 | 01:34 PM
WUnderwood's Avatar
did you install it facing the right way?
not trying to be a smart aleck
Old Feb 3, 2008 | 01:40 PM
MCummings's Avatar
I don't really see the EGT issue here?
Stock, they can get to 1,400*F. The '04.5 motors have a higher threshold for EGT"s than the previous models. I don't have the sources/data here with me, but it's here on DTR.
Merrick
Old Feb 3, 2008 | 01:59 PM
jlibert's Avatar
imho, i don't think there is any way the aeroturbine could possibly be more restrictive than the factory cat. You can hold the cat up to the sun in the middle of summer and not see a speck of light through it.
Old Feb 3, 2008 | 02:11 PM
sallyman1's Avatar
true. my aero4040xl has a 4" dia. hole right threw the entire thing. Could it be because i used factory 4" . Is the factory dodge 4" mandrel bent? Would I of been better of to buty like a aftermarket 4" exhaust instead like mbrp or ats etc...?
Old Feb 3, 2008 | 05:09 PM
Minwy's Avatar
These truck run hot, the smarty is the only power adder that will actually lower egts, at the expense of hotter pistons so I still think its a trade off. Make the pistons really hot or make the turbo hot, personally the turbo is lots cheaper to replace.
Old Feb 3, 2008 | 06:23 PM
Ghamilton's Avatar
I'm going to keep an eye on this thread. I was just getting ready to put the 4040XL on my truck. Now I'm second guessing even though I don't think it could be the cause for the high EGTs. I've been told just to leave the factory exhaust alone because it's already 4".
Greg.
Old Feb 4, 2008 | 01:19 PM
dodchall70's Avatar
I just put the 4040XL on my truck and I love it. Makes a nice deep tone, sounds great. I have not had a chance to tow anything yet, but driving around town it has seemed to lower my egt's by about 100*.
Old Feb 4, 2008 | 04:41 PM
sallyman1's Avatar
yes it seems like a good muffler. i put rings to the back and word AERO from left to right or rear to front so im sure i installed it correctly
sallyman1
Jan 18, 2008 08:10 AM
sallyman1
Jan 3, 2008 06:14 PM
barryp
18
Feb 13, 2007 05:34 PM
local601
Apr 13, 2005 04:01 PM
Pa outlaw
Dec 12, 2002 12:00 AM
