WINspeed Heater Grid Delete Test Complete!
Old Jan 20, 2008 | 05:24 PM
  #46
seafish's Avatar
Originally Posted by Ghost Ram
what about mounting it in between two blocks of aluminum to contain the heat and setting it aside somewhere in the engine bay? just thinking out loud......
Ghost Ram, I have not yet installed my GDP intake horn and grid delete block, but I think your idea is a good one; of course aluminum does conduct heat very well, so depending on how hot those 2 plates get, one might want to use another material, or perhaps use both steel and an aluminum plate with some sort of ceramic material in between. Definitely let us know how you develop this idea!!
Old Jan 20, 2008 | 06:27 PM
  #47
JWash1's Avatar
Well I just bit the bullet and ordered one from the EBay store. I don't expect much of a noticeable performance gain, but every little bit helps.
Old Jan 20, 2008 | 07:13 PM
  #48
Rpainter's Avatar
I installed my grid heater delete and a cfm intake horn saturday. I did notice about 100 degree drop in egt but the weird thing is I gained about 4 psi of boost??anyone else notice this
Old Jan 20, 2008 | 07:18 PM
  #49
gus's 03's Avatar
where are you takeing boost from? boost bolt?
i wouldnt have thought that much of a presure drop across the hon and grd, but i guess its possable.
Old Jan 20, 2008 | 07:33 PM
  #50
Rpainter's Avatar
boost out of the cfm horn same place of the stocker
Old Jan 20, 2008 | 08:26 PM
  #51
Deezel Nate's Avatar
My truck will fire up with it's 20* without the grid, but it doesn't like it. I figure the grid is there, may as well use it. That delete would be ok in the summer though I don't think it's worth the hassle for what, 10hp?
Old Jan 20, 2008 | 08:35 PM
  #52
Ghost Ram's Avatar
after reading the descriptions of the heater and iat sensors in the service manual i think i would still get a code even if i leave the grid hooked up and relocate it. there are two iat sensors, one at the air filter which is a combination baro sensor and the other is on the manifold which is a combination map sensor. if the ecm doesnt see a difference in the temps between the two iat's i believe it will still set a code.
Old Jan 20, 2008 | 10:34 PM
  #53
levigarrett76's Avatar
Originally Posted by Deezel Nate
Will your truck even start when it's cold without the grid, or are you guys using ether now?
Started mine this morning at 15* in 10-15 mph wind. Cranked 1 second or so longer than usual but fired right up and went to high idle pretty quick. Just a light blue smoke
She had been sitting over 12 hours.
Should be another cold one in the morn.
Old Jan 21, 2008 | 07:06 AM
  #54
jrussell's Avatar
Boost is a result of restriction in the system. Less restriction = less boost. No idea why you would see more? Maybe colder than normal outside temps?
Old Jan 21, 2008 | 09:15 AM
  #55
Ghost Ram's Avatar
started mine up this morning it was 20 deg. out, it started right up but ran very rough and tons of blue smoke poured out for a while. i think im leaving my grid in at least through the winter because i would hate to get stuck somewhere w/ a truck that wont start. i will try the delete in the summer on the dyno or the track and post my results then.
Old Jan 21, 2008 | 09:57 AM
  #56
Matt S's Avatar
I agree. This kind of gain isn't high on the bang for the buck or downside of cold starts and codes.
Old Jan 21, 2008 | 10:42 AM
  #57
I started mine up this morning with the delete....temp said 15* Fired right up, no rough running hardly any smoke, i have yet to get a code?
Old Jan 21, 2008 | 02:55 PM
  #58
jlibert's Avatar
polished mine and installed it the other day
Old Jan 21, 2008 | 10:46 PM
  #59
gus's 03's Avatar
corect. so if he is reading boost post restriction, it would increse.
Old Jan 22, 2008 | 06:11 AM
  #60
any one else have some coldstart experience with the delete?
