Where 2 get cat 2 micron?
Based on Wix's opinion that their OE filter for the HPCR doesn't meet specs but is "good enough" I will NEVER run a wix fuel filter in my truck. They don't match the specs of the filter they copy...
I have 23K on mine and still running within .5psi of new.
Correct, its not a f/w sep.
Wix filters are 2 microns nominal and who knows what absolute. Cat filters are 2um absolute...
if you want the very best filter set up get two napa 4770 bases and series them install a fleetguard fs1000 in the first followed by a fs5320 in the second one. next mount them in front of the fuel tank and cut the line from the tank and connect the filters. next do not change the filters until you have a 3 psi drop and you should never have to change the stock filter.
IMHO I want a little looser filter for my first filter, like the Baldwin BF1212 at 20um. The Fleetguard FS1212 isn't as efficient at f/w sep as the Baldwin. The reason is I have three filters and want a step between them all, so the 20um catches the big stuff, the 5um the next biggest, then all the 2um has to worry about is the fine stuff. This is also the reason I don't like the two filters together under the truck, albeit personal preference, I want the filtration sequential for maximum filter life. Lets face it the OE filter will have to be replaced, so might as well use it.
Here is more of the data I have collected, its by means not all, but most people will find it to be plenty. http://www.cumminsforum.com/forum/3r...lter-data.html
GaCamper
22
Dec 10, 2013 09:43 PM
AH64ID
66
Dec 20, 2012 08:09 AM
03RAM2500
Jan 11, 2009 05:21 PM
B.Law
57
Jun 1, 2006 10:46 AM
