Where 2 get cat 2 micron?
The filter head can be bought the same place you get the filter in most cases. I got both of mine at Kenworth, however mine takes "O-ring to AN" fittings which are kinda expensive. The filter heads were under $20 but you can get the same ones at NAPA that have regular NTP type fittings. Depends on what type of hose your planning on using. I eliminated all my banjo fittings and replaced them with AN's so this setup worked for me.
I just changed mine at 26,000 miles but I was running two side by side. One alone has much greater filtering capacity than the stock fuel filter. I probably could have gone longer. I cut open one filter and found nothing that made me think otherwise.
Yes these are not dedicated fuel water separators filters, usually secondary fuel filters.
Where to find them:
http://www.cat.com/dealer-locator
Where to find them:
