When are pushrods needed?
Old Jun 16, 2008 | 03:56 PM
wap's Avatar
wap
I am in the process of replaceing my injectors, head bolts, and I have a set of valve springs on the way. My next round of mods will be dual cp3s, and maybe an exhaust manifold (though I hate to buy that twice) and intake manifold. After that twins, and possibley a cam, and that will be about it except for maybe some h2o meth and or bigger injectors.
Given that and my current mods, do I need 4130 pushrods?
I have everything apart and it would be simple to go ahead and drop them in, but I really dont need to spend anymore right now.
Any input is apreciated.
Old Jun 16, 2008 | 04:51 PM
cquestad's Avatar
Never...
Well...atr least till 1000 plus hp.
Old Jun 16, 2008 | 06:36 PM
tritont's Avatar
high rpm's is going to push them to their limits but, unless you're sled pulling with the 4K tune... you shouldn't have a problem.
Or, you could do like I did and install some Manton rods just because. They weren't that expensive and having an aftermarket cam and springs it's just an extra piece of mind.
Old Jun 16, 2008 | 07:39 PM
Billy Ram's Avatar
The stock push rods are quite strong and wouldn't need changing while running a stock cam along with mild after market springs. "110 lb seat pressure" When you run a aggressive cam with heavy springs the stock push rods will flex and eventually bend. I wouldn't worry about push rods untill I had a problem. They are easy to change if needed.
Old Jun 16, 2008 | 09:28 PM
nelrod's Avatar
Hey Wap, it's only money. Seriously, I probably didn't need them l, but after spending a lot of money to improve valve train, I wanted to make it as strong as possible, so for another ? $250 -- got some chrome moly pushrods, but they can wait -- as someone said. Good luck.
Old Jun 16, 2008 | 09:39 PM
53 willys's Avatar
I would think it would be better to have a "fuse" so to speak..
I would rather bend a pushrod...if you do HD rods the next thing on line is a bent or broken valve right??? If you do rods you may want burly valves too?
Old Jun 17, 2008 | 06:55 AM
wap's Avatar
wap
All great advice fellas, thanks for the help. Since I am in a tight right now I will just hold off. The sticks and springs are already on my visa (and the only thing on it) and thats 2 things too much, I hate using credit cards unless I have to. So I will just hold out, I would kinda like to have but like you said Mark, a bent pushrod may be the lesser of two evils.
Thanks again guys
Old Jun 17, 2008 | 06:58 AM
GOT BOOST?'s Avatar
I am with Mark on this one, it is much easier to change a pushrod than a valve, cam or tappet. Jay
southpawslingr1
Nov 10, 2011 07:50 AM
gecoveyc
Jul 1, 2011 04:25 PM
powerstrokin03
Apr 28, 2007 03:26 AM
Crimedog
Oct 17, 2005 04:23 PM
Bradtothebone
Jan 6, 2005 12:57 AM
