Wheel help
Wheel help
Will these fit my truck. I hate to ask, but can't tell by the specs..
http://www.4wheelparts.com/Wheels/We...%2fR408-88596D
You'll be fine w/ the 285's in your sig. The only problem (if you don't mind the look) they will stick out some past the wheel well. If your thinking on bigger tires. Then stick to a 5.5" or 6" BS. Ideally a 6" BS w/o rubbing your upper control arm at full lock or the back corner of the front wheel well and still tucked in like the stock wheel.
I have the BW flares on already so I hope it won't be to bad. The 285' are 17's not sure what i will run with the 18's. The good thing is i got a Kore leveling kit in garage ready to go on.
jet
Dec 15, 2002 08:11 AM
