Whats needed for a Drive Pressure gauge??
Like the title says....whats needed??? Include everything....from start to finish and range of gauge (DiPricol).
TIA!!!
TIA!!!
100psi guage
3/16" SS brake line/tube
homemade soot filter
a couple compression fittings
and either drill and tap the manifold or if your lucky you can plumb it in with your pyro...but that can be tricky if your feral is already seated.
nothing to them really....
Can you elaborate on the piggybacking with the pyro???
A DP gauge can help show how much backpressure you have in the manifold/head. This is very valuable info when running a turbo on the ragged edge, if DP is too high (over 1:1) possible HG failure.
Its also very helpful when tuning in twins, help adjust WG's to produce as close to 1:1 as possible.
sallyman1
39
02-29-2008 01:14 AM
stroker400
09-19-2007 12:44 AM
bthomas
11-17-2006 12:28 PM
big red psd cc
14
02-25-2005 11:41 PM
ckennedy
11-11-2004 10:56 AM
