What's the difference?
Old Jan 24, 2007 | 08:32 PM
wegotlabs's Avatar
I hve searched the forums and I have not been able to find a thread explaining the difference in the 'stages' of air flters.
So what is the difference in the 'stages' of filters?
Thanks for you input, I am still learning all the cool stuff about CTD's performance accessories.
Thanks
wegotlabs
Old Jan 24, 2007 | 09:22 PM
RamWheelsBy4's Avatar
If you are referring to the AFE Stage I and AFE Stage II that people refer to, then it is just two different air intake products. AFE Stage I is the filter box and filter only. It uses a 4" filter inlet size filter. The AFE Stage II is the filter box and down tube to the turbo inlet all in one product. It uses a bigger filter with a 6" filter inlet size filter.
Old Jan 24, 2007 | 09:27 PM
D.Wiggs's Avatar
Isn't there supposedly a Stage 3 in the works?
Old Jan 24, 2007 | 09:32 PM
53 willys's Avatar
Yep, check it out
Old Jan 24, 2007 | 09:37 PM
D.Wiggs's Avatar
You S.O.B.!!
Old Jan 24, 2007 | 09:44 PM
wegotlabs's Avatar
Thanks for your help, but I have other questions....
Is AFE the only intake system that does the different stages?
It sounds like not only is the setup different, but it sounds like there is a larger intake tube rather than using thestock tube, is this correct?
Old Jan 24, 2007 | 09:48 PM
D.Wiggs's Avatar
The AFE Stage 2 with ProGuard 7 is definitely your best store-bought option!
CMN_NOT_STROKN
Nov 22, 2024 02:55 PM
GO 4LO
Feb 20, 2003 02:08 PM
Cutthroat
Dec 29, 2002 12:38 PM
j
Nov 23, 2002 05:51 PM
jet
Nov 16, 2002 09:32 PM
